Old 10-29-2017, 08:09 PM   #1
AZ986S's Avatar
Having trouble with heel-toes
So they say it's good to practice heel toeing on the street. Except there is no way that you are applying as much brake pressure on the street as on the track! My issue is during hard braking, say downshifting from 4th to 3rd or 3rd to 2nd, it seems like I either get the lurch forward from too much blipping, or not enough blip and get a slight rear wheel lockup. I think the issue is that the gas pedal is too high when I am braking hard. Another thing that happens to me occasionally is that from 3rd to 2nd, I keep partial gas pedal while braking even after the heel toe is complete, making me freak out why I am not braking quickly enough!!! Can the pedals be moved? Or do I need an aftermarket gas pedal?
By the way, those Federal 595 RS-R tires are phenomenal! I now have 10 heat cycles in them and they have amazing grip, somewhere in the 34-35 psi hot range. Higher than that, and they get a little greasy. They seem to be wearing nicely too.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 10-29-2017, 08:46 PM   #2
The stock pedals cannot be moved or adjusted.
Is your throttle too high? My problem was that the throttle was too low and it was almost impossible to roll my foot over far enough to reliably hit the throttle. I talked to a few racers and they recommended a throttle lifter plate. With the throttle pedal adjusted up, I had no problem heel and toeing. I still use it in my Spec Boxster today. See it here: Rennline Adjustable Lifter Plate-Rennline, Inc.
I also installed the throttle extension to make it easier to reach the throttle so I can more easily get to the throttle by using the outside of the upper portion of my foot or using the heel: Rennline Throttle Extension - Heel Toe-Rennline, Inc.
There is also a DIY throttle extension (but it doesn't lift the throttle higher): http://986forum.com/forums/diy-project-guides/61064-pedal-extension.html
In your case, maybe you need a fully adjustable throttle pedal like this: http://www.rennline.com/Pedals-Fully-Adjustable/products/1128/
I hope this gets you pointed in the right direction.
Old 10-30-2017, 06:12 AM   #3
steved0x's Avatar
What helped me to get heel/toe down was practicing on Forza with a Fanatec Wheel and clubsport pedals, that have a load cell for the brakes so it is very realistic. I was trying to learn Sebring, and was also working on my heel/toe, and I must have done dozens (maybe hundreds? but dozens for sure) Heel/toe downshifts and it really helped give me the muscle memory for the right sequence of motions. Prior to this I had the experience that my left would would not release the clutch if my right foot was on the brake still, and so I ended up giving it gas and going into gear as I finished my braking.
Disclosure - I have a pedal extension - I have actually had two - the first one was quite big, and I got to where I didn't need it, so I moved to a smaller one. I have pretty wide feet too.
Both of my pedal extensions were this brand:
SRP Porsche 986 Boxster Aluminum Racing Pedal
The first one I had was the double extension, and then 2nd one was the "regular" extension.
Old 10-30-2017, 09:15 AM   #4
The height of the brake pedal can be changed by adjusting the brake pedal pushrod located behind the master cylinder. As you mentioned, the right height for the street won't be what you want on the track.
spendy is offline   Reply With Quote
Old 10-30-2017, 09:48 AM   #5
The Radium King's Avatar
are you actually using heel toe, or side of foot? i'm a side of foot guy and yeah, sometimes i am so deep in the brakes that i get into the gas before i want. you can always get this ...
https://www.auto-blip.com/
Old 10-30-2017, 11:35 AM   #6
AZ986S's Avatar
I roll over and use the side of my foot mostly.
i'm a side of foot guy and yeah, sometimes i am so deep in the brakes that i get into the gas before i want. you can always get this ... https://www.auto-blip.com/
I think that is my problem too.
Old 10-30-2017, 11:56 AM   #7
A suggestion, don't just blip and dump the clutch. If you nail the blimp and dump, as you were saying, it works perfectly, but in the heat of a race, things are not perfect.
What I've been doing lately is blipping the gas, but not taking my foot completely off the gas, leaving it revved up a little bit and at the same time letting the clutch out slowly, not just dumping it. If you do this, the transition is very smooth and you can usually instantly feel if you've over accelerated or under accelerated and can correct any miscalculation.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 10-30-2017, 01:15 PM   #8
steved0x's Avatar
I am side of foot too, and sometimes I get into the gas hen I am braking, and I am like "What the heck is happening" - a couple times I have gone off, and when I get into the clutch, the car revs up like crazy. This only usually happens at The FIRM, which is a lower speed track with a lot of braking. Also I think because it is lower speed and with a lot of runoff, it is easy to push it and really explore the limits of the car. I'm not sure why but it only ever seems to happen there so I have to be really attentive about my foot placement when braking.
Old 10-30-2017, 06:08 PM   #9
AZ986S's Avatar
Exactly what I said too! WTH is happening!
So thanks for all the responses. I think I'm going to go the way of the Rennline adjustable throttle pedal. Maybe I should think about getting racing shoes too
Old 10-31-2017, 01:07 AM   #10
fridsten's Avatar
Instead of struggling with this, you could simply get a Cayman GT4. It blips the throttle for you on downshifts...
fridsten is offline   Reply With Quote
