Old 01-22-2007, 07:58 AM   #1
Burning rubber smell
I have a 01 S and whenever I step outside after driving it I smell a slight burning rubber smell. It's coming from the back end. Does anyone have any clues?
Thanks.
arkaplan is offline   Reply With Quote
Old 01-22-2007, 08:06 AM   #2
well let be the first to say it might be your clutch.....I've learned this from experience....you might have smoked/burnt your clutch....you'd have to give more details tho....
super66 is offline   Reply With Quote
Old 01-22-2007, 09:06 AM   #3
It doesn't seem to have any problems shifting gears. What other details would you need?
Old 01-22-2007, 09:35 AM   #4
bmussatti
Posts: n/a
How long have you been driving a stick?
No belts are rubbing??
Old 01-22-2007, 10:24 AM   #5
Send a message via AIM to Travis
I would start with checking the obvious.
Things of rubber like material.
1. Inside of tire (is it rubbing)
2. Belts (wear & tear)
3. Hoses (wear & tear)
4. Exhaust (Do you have any material caught that may be burning)
I had a problem (not on Box) where I ran over a bike inter-tube on the road and it had got wrapped on my exhaust, when I pulled over I was able to remove it but I swear I smelled rubber for the next few months.
Then of course re-think your shifting pattern if needed
Thanks.
Travis is offline   Reply With Quote
Old 01-22-2007, 12:26 PM   #6
Do you like to leave small deposits of tire rubber on the street for others to enjoy? Cuz that can also cause the smell....you know...
Just thought I'd mention that
-David
1995 Silverado V8 - Green/Tan (FOR SALE)
2000 Boxster S - Ocean Blue/Graphite Grey
2002 GSXR750 - Blue/White
http://www.darkoven.com/sig.jpg
David N. is offline   Reply With Quote
Old 01-22-2007, 12:39 PM   #7
Hmmmm...I have no idea where a smell like that could be coming from...
http://i84.photobucket.com/albums/k2...izzlysmall.jpg
'97 986
Cheating Death on 19" Wheels
...no catastrophic engine failure ...yet
Grizzly is offline   Reply With Quote
Old 01-22-2007, 12:43 PM   #8
Thanks.
I would check for an oil leak. I have found that the synthetic oil used in our cars does have a rubber type smell when it burns. You might have a small leak that's dripping on a heated portion of your engine or exhaust and causing the smell. If it drips on the catalytic converter like mine did, you get some impressive smoke coming from the side vents as well.
http://members.shaw.ca/randipfeiffer/images/avatar2.JPG
2002 Boxster S - Basalt Black
bringer666 is offline   Reply With Quote
Old 01-22-2007, 01:22 PM   #9
I think I sometimes detect the same kind of smell from my Boxster. Not EVERY time I get out, but sometimes I smell a little what smells like oil/rubber burning.
I figure as long as there's enough oil in the engine... and it's not all the time... it's probably some minor little drip here or there that just happens to get on something hot. I'm going to give the undercarriage a once over when I change the oil later this week.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
