Old 04-25-2026, 07:31 PM   #1
2004 3.2 3 chain motor with cam actuator leak
Noticed a slight leak that appears to be coming from the RH cam actuator.
Am I correct that this can be removed without and danger to cam timing?
I’d like to seal it up but I don’t want to remove it if I need to lock the cams or anything.
With the Variocam + system, not having the slipper type guide rails that adjust timing, I would think it would be safe.
Anyone done this job or any advice?
DonQ is online now   Reply With Quote
Old 04-28-2026, 12:36 AM   #2
If I interpret that correctly, the actuater should only be removed when in vertical position. With engine in the car this would be impossible.
997_986 is offline   Reply With Quote
Old 04-28-2026, 08:24 AM   #3
redpepperracing's Avatar
It says right at the top 'Engine removed' so yeah...
redpepperracing is offline   Reply With Quote
