Old 01-13-2026, 07:15 PM   #1
Engine tapping noise
Hi, I decided to post on here about my engine problems with my Boxster. full disclosure I bought the car at 17 (I'm 19 now) so money is tight to repair it. a few months ago my car began having oil pressure issues which were solved with an oil change (no glitter in the oil) and a new filter. a week after this however due to a lose connecter by the ignition switch. upon starting it back up it began making a knocking/ tapping sound from the engine which increases with the rpms. the car has high miles 160k but has a mountain of service records dating back to when it was new with all the typical Boxster issues like the ims, water pump and rms all being done. The car has sat ever since because of college but I'm ready to start getting into the issues. any help would be a life saver
2003beater986 is offline   Reply With Quote
Old 01-14-2026, 08:57 PM   #2
Tapping suggests lifters failing to pump up.. this would be an engine out situation for most people. What weight / type of oil did you use?
Hayabusa3 is offline   Reply With Quote
Old 01-16-2026, 06:31 PM   #3
I use 0w40 in the winter and 5w40 in the summer. I'm pretty sure at that point I had went to 5w40.
