Old 06-03-2025, 11:29 AM   #1
First Blackstone Report
I was a little nervous about what the results would be. But I'm pretty pleased with this report. Whew!
1997 with 47,000 mile. I bought it about 2 years ago, with 36,000 miles.
ecruz is online now   Reply With Quote
Old 06-04-2025, 05:12 AM   #2
Looks good to me as well. Would not use 0W-40 for 5.000 mls, stick to 5W-50 what is btw the recommendation from Porsche for these engines (now).
Old 06-04-2025, 06:15 AM   #3
I didn't know that 5W-50 was recommended. Thanks! I guess I need to do another oil change.
Old 06-05-2025, 11:20 PM   #4
Yes, 996 + 986 have a (Classic) Porsche recommendation for 5W-50, I would use a quality fully synthetic brand. They even have a number for 1l, PCG-043-210-40.
No need to buy this extreme expensive stuff ;-)
Edit: Full/High SAPS
Old 06-06-2025, 12:53 AM   #5
As 997_996 says, when Porsche's developed their "classic" oil for the 986, they chose 5w50. Probably has to do with age and wear of these engines in general now. A lot of 0w40 and 5w40 oils are still on the approved list of porsche. The most important is choosing a A40 approved oil, next is choosing a quality oil that has some proven performance over time.
A 0w40 oil should still be fine, allthou It is said to avoid the mobil 0w40 because it shears and looses viscosity quickly. I choose mobil 5w40 instead with some ceratec added. I suspect other 0w40 oils like castrol is higher quality.
Mobil does have a 5w50 oil now with porsche A40 spec. The Mobil 1 Peak Life 5W-50. I'm running a low temp thermostat which lowers oil temps and live in northern europe, so I will stick with 5w40 unless it starts consuming oil.
Got my car back from the indy now, and they used Castrol 0w40. I will run with this until next oilchange.
Petecomplete is offline   Reply With Quote
Old 06-06-2025, 12:31 PM   #6
i don't understand how a low temp thermostat allows lower oil temps, isnt it just it just go wide open sooner on the warm up ? I imagine low and regular temp thermostats are both fully open when car warms up after first 5 minutes no ?
theiceman is offline   Reply With Quote
Old 06-10-2025, 06:50 AM   #7
This is from the LN Engineering website, in the section describing their spin on filter adapter:
"Oil change interval should not exceed 6 months or 5,000 miles for street using a 0w40 or 5w40 viscosity motor oil... higher viscosity is not recommended".
Is that only for a spin on filter or is this outdated info?
Old 06-12-2025, 03:41 AM   #8
1998 Boxster Silver/Red
It doesn't. Period. Fully open.
And, yes.
Math and science.
1998 Porsche Boxster
