Old 03-26-2025, 02:02 AM   #1
02 Softtop on a 99
Hey all,
yesterday I put the softtop from an 02 car in my 99.
Replacing is pretty much straight forward and went without any hassle.
But my old softtop had the B-Pillar microswitch, the new one does not...
I already replaced the roof transmission on the driverside with one from 02, but where can I get the cable to connect to the transmission?
Is there a kit being sold somewhere to just replace the B-Pillar microswitch with a longer cable to connect to the transmission?
Also do I need to replace the softtop motor cover? Mine being a 99 has a microswitch in it, newer ones dont. I will probably also need to replace the relay, but I firstly need to know how to Connect the microswitch to the transmission.
Grateful for any advice on how to tackle this "issue"
dennisleonardok is offline   Reply With Quote
Old 03-26-2025, 03:42 AM   #2
I don't know if it couldn't be solved quite simply by replacing the old with a new relay, because as long as your control expects the switches, you have to supply them. A new relay would probably not have all that. But this is only a suggestion and a very long shot ...
The relais from MY 00 onwards is 986 618 199 00 and sits above the fusebox ...
Old 03-28-2025, 01:50 AM   #3
Yes thanks, but this wont fix the issue with the B-Pillar microswitch
Old 04-21-2025, 06:27 PM   #4
Toppy
Toppy986's Avatar
Read this link, hopefully Mike can help you
https://986forum.com/forums/boxster-general-discussions/84105-convertible-top-replacement.html
1999 Boxster
Arena Red/Graphite Grey Interior/Black 03 Top/550 All Red Tail Lights
Toppy986 is offline   Reply With Quote
Tags
986 , facelift , plastic window , prefacelift , softtop
