Old 03-05-2025, 12:55 AM   #1
DME & Fuel Pump relays
HI there having a major issue with the 986 2003 2.7 Boxster
had a slight stutter when accelerating hard and was advised to change plugs and coils
Got the car up in the air wheels off and replaced the coils and spark plug used like for like replacements all part numbers the same Beru coils and Bosch spark plugs it was very fiddley but managed to get them changed. Al torqued up and done one cylinder at a time so no chance of getting the connectors wrong
the battery was off being charged, replaced the battery and the engine turns over at a good speed but does not fire up.
I have checked all the fuses in the foot well nothing blown, before i get her back up in the air and start rechecking my work i have been told it might be worth checking the DME relay and the fuel pump relay
i can see these (Just) above the fuses a set of relays but not sure which one is which or if these can be local part shop replacements or if i need to order from Porsche?
Ohrammer is offline   Reply With Quote
Old 03-05-2025, 01:29 AM   #2
Here's 996 relays layout. Should be very much same and same locations (some at the footwell and some in trunk 986 / enginebay 996).
2001 996 C2 Manual
Old 03-05-2025, 07:27 AM   #3
thanks for the information
Could i take a relay from say the flasher and put it in the fuel pump socket to test the relay?
Old 03-05-2025, 07:58 AM   #4
question says you might be over your head. Get someone with some relay experience to remove the relay and jump the power to see if the relay is not working. Good Luck
2003 Boxster S, Chevy LS3.
obthomas is online now   Reply With Quote
Old 03-06-2025, 05:23 AM   #5
So i have tested every relay in the car both in the trunk and footwell they are all good checked every fuse none have blown seems i need to get back under the car and check each bloody coil and plug
Not very happy and wish Santa had brought me a car lift and not a new set of torque wrenches
Old 03-10-2025, 03:14 PM   #6
Fuel pump?
went through this ritual, after testing all the relays, my fuel, while pumping fuel, failed a pressure test.
I spent a lot of time before I figured this out
Luckyman01 is offline   Reply With Quote
Old 03-13-2025, 12:29 PM   #7
consider the fuel pump
Thats were I ended up after an adventure through all those relays, My pump while appearing to work (it did pump gas) it was not achieving enough continious pressure.
Old 03-15-2025, 09:18 AM   #8
This would mean that the old plugs and coils were still in order and the pump was starting to go. You would have to check all the old plugs and measure the coils or check the pump straight away.
It would be interesting to read what was ultimately the cause...
Old 05-12-2025, 01:23 AM   #9
SO just to close this post off, it was the crankshaft position sensor which had died. a real ******************** to change as you need the longest Hex bit you can find
Old 05-12-2025, 02:26 AM   #10
Thanks for yor final reply and happy you sorted it
