Old 08-02-2025, 03:07 AM   #661
Registered Member
Originally Posted by LoneWolfGal View Post
I'm still alive, still getting things set up at my new place. In the meantime, since putting the car on jack stands will be my first order of business, I've been thinking about how to make the process less frustrating.
Consider the following:
With the floor jack under the rear crossmember, jack up the entire back of the car and place jackstands under the left and right side jacking points (just ahead of the wheel wells) and lower the car onto them.
At the front, jack from just behind the front wheel wells, placing the jack well inboard (you will see a good structural location about 18” in). That will lift the front of the car, at which point you can place jackstands at both of the front jacking points, lower the front of the car and pull the jack out.
In summary, lift the car twice and place four jackstands. Easy easy.
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
Old 08-02-2025, 10:01 PM   #662
LoneWolfGal's Avatar
That should work, but you don't need to do all that. The suspension and body are stiff enough that even if the lift points are off-center, the lean won't be all that much.
Here's a video:
https://www.youtube.com/watch?v=fDA-qI5HsIU
Thanks, Al. That was one of the first videos I watched when I first got the car. I like John Salt's videos.
I've had the car on jack stands four times now, using Salt's (and Tom Coradeschi's) method. Which works fine IF you don't need to elevate the car higher than 14" or so. As Salt observed, when raised at the recommended jacking points, front and rear, the car is higher on one side. There's no way around it.
My jack stands have a maximum height of almost 20", and I want every inch of that, to have enough room to drop the engine and transmission. A 14" jack stand height won't cut it. I can't conceive of any way I can achieve maximum height — on BOTH sides — without using something like my floor jack cross member to lift the car evenly and level, both sides at once. I've been thinking about this problem for a long time and I'm fairly certain my design will do the job.
So I'm going to proceed with fabrication (i.e., cutting the channel to length with a hacksaw) of the floor jack cross member, which I have dubbed "The Lift Master" (patent pending). Any bets on whether it will work?
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is online now   Reply With Quote
Old 08-03-2025, 03:04 PM   #663
Rereading your post, may I assume by "With the floor jack under the rear crossmember" and "just behind the front wheel wells, placing the jack well inboard (you will see a good structural location about 18” in)," you're referring to the same lift points John Salt used in his video? Otherwise, according to Porsche, damage to the undercarriage can result.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
Old 08-03-2025, 04:21 PM   #664
piper6909's Avatar
I've had the car on jack stands four times now, using Salt's (and tcoradeschi's) method. Which works fine IF you don't need to elevate the car higher than 14" or so. As Salt observed, when raised at the recommended jacking points, front and rear, the car is higher on one side. There's no way around it.
What's the lift on your jack? if it's about 22-24", then the low side should be at around the 20" you need, and the high side will be more than high enough, naturally. .
2010 Subaru Forester
Old 08-03-2025, 06:35 PM   #665
My floor jack's maximum height is 19.5 inches. My brother's jack is approximately the same. Not enough to raise both sides to 20 inches. I could buy or make tall ramps for all four wheels and stick a platform made of 2x8s or 2x10s under the jack. That's one solution I considered. Constructing the Lift Master™ is even simpler: hacksaw 12 inches off a 48-inch-long steel channel, attach a couple of 5-inch rubber pads .— and it's finished! (Well... my OCD-lite will probably compel me to spray it yellow to match the floor jack, so there's that.) There's adequate clearance to get the Lift Master™ under the front or back with its channel upside down over the jack's pad. The pad will be in the trough, preventing the channel from slipping. The arms will extend out 18 inches (from the jack's centerline) on each side, pads positioned under the lift points.
C'mon, Al — you don't think it's a simple, semi-innovative solution?
Okay, where's Grant?!
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
Old 08-04-2025, 02:14 AM   #666
Registered Member
I can’t say, as I’ve never seen the video. It’s a method I’ve been using since 2006. I put some photos up in a post, probably on the Pelican Parts forum, many years ago…
Tom Coradeschi
03 Boxster
Old 08-04-2025, 09:14 AM   #667
Tom, is there another Pelican Parts forum besides this one? Also, if you want to see Salt's video it can be arranged, assuming you can present proper identification.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
Old 08-04-2025, 04:41 PM   #668
my personal jacking procedure
This is what I do whenever I need to jack the car high on four jackstands, please note that this is my personal procedure that has worked for me since 2007 I first got my 987CS, and now I use it on the 981CS
1) get the rear wheels on ramps
2) raise the front driver side with the floor jack, enough to put a 4x4 underneath the front left wheel (this extra step is required as my car is lowered..), otherwise the jack and the piece of wood will not fit under the front bumper
3) get the floor jack centered with the frunk emblem using a 2x6x24 piece of wood under the front part of the subframe and raise the entire front, then use two stands under the facory jacking points (I use 'jack pucks' attached to the jacking points) between the jack and the frame.
4) I center the jack using the exhaust pipes as a centering point and use a 4x4x36 under the bolts that connect the diagonal braces to the rear suspension mounting points, raise the rear axle just enough to raise the wheels to allow me to remove the ramps and install the rear jack stands.
IF, needed to get the car higher, I "very carefully", slowly raise the front a bit (one click on the stands) and then move to the rear axle and do the same with the 4x4 Note: you need to raise each axle just a bit to avoid the risk of the pucks slipping from the jack stands.
Please note that I have the Quick Jack, but sometimes just thinking about the weight of the ramps gives me a back ache..
Old 08-05-2025, 02:23 AM   #669
Registered Member
https://forums.pelicanparts.com/boxster-cayman-forum/729592-what-kinds-floor-jacks-2.html#post7581158
Tom Coradeschi
03 Boxster
