Old 10-01-2023, 11:45 AM   #1
Registered Member
Sirius XM FM Adaptor Relay Tripping Alarm, and causing a no-start?
Lately I've been trying to ID an intermittent problem which seems to slowly be getting worse.
The situation: 2002 Boxster 2.7 with a professionally installed SiriusXM converter, and a Pioneer radio from Crutchfield which I installed.
The symptoms: The car runs great. Normally the car turns on when I turn the key, and the satellite radio and Pioneer radio come right up. The alarm will chirp when I lock the car (even though I thought that I had deactivated that.)
Occasionally when I try to start the car the Sirius unit and the radio will be dead, and the car won't start. I'd noticed a clicking sound from the radio console which I've identified as the SiriusXM FMDA25 FM Direct Adaptor. It's a small black box which switches between the AM/FM Antenna and the Satellite Radio FM out plug.
Using my Durametric OBD reader, I also noticed an "Alarm I48 - Fault 25 "Status lead, signal converter, short circuit to B+". When it happens, it can happen multiple times.
I haven't found much of an explanation for this fault, but I suspect that the "B+" refers to Battery-plus or +12V (as opposed to a short to ground).
If there is no clicking sound, then the tunes come up fine and the car starts.
The relays only seem to cost ~$15-$20, so I'm going to swap it out and see what happens.
Anyone else ever run into this?
Last edited by jluetjen; 10-04-2023 at 02:17 PM. Reason: added extra symptom - alarm chirp
jluetjen is offline   Reply With Quote
Old 10-04-2023, 02:16 PM   #2
Registered Member
Just logging the solution.
I replaced the relay, and the new one started clicking even faster when the car wouldn't start.
So I pulled out the entire SiriusXM system, and now the car and alarm work fine.
