08-10-2023, 12:41 PM
Center Wind Deflector
I want to add the wind deflector to my 986. I've seen used ones for $100ish or I can buy a whole new "kit" for $700ish (which I wouldn't do). The used ones I'm looking at have the rubber seal around the edge and appear to have some sort of clips at the top corners. Is that all I need to install one or are there other clips, pieces, etc., that I'd have to source?
Thanks,
E-
08-10-2023, 01:14 PM
2003 Boxster S
09-12-2023, 09:22 AM
09-12-2023, 11:40 AM
1998 Boxster Silver/Red
After taking mine off for whatever... when reinstalling I slip it into that lower part then clicking into place the two top tabs. When it appears secure I give each top edge a pull towards the rear of the car to ensure it's snug.
Yours looks good. Go drive.
1998 Porsche Boxster
09-12-2023, 12:23 PM
Thanks! It seemed fine, I just didn't know why the Pelican kit has 3 clips.
09-13-2023, 11:16 PM
You absolutely need the center "clip" (lip).
Buy and install it, or buy it and another wind deflector later when you lose this one on the highway.
09-14-2023, 03:39 AM
Was the screen an option? Were 986s sold with zero screen hardware on the rollbar?
Thanks, PW.
09-14-2023, 06:09 AM
Thanks, PW.
For the plexiglass center windscreen, it has the 2 clips at the top, just not the one at the bottom/center. There is nothing inside the roll hoops for the "screens". Not sure if there should be something there or not.
Reason: Adding to response
09-14-2023, 06:00 PM
MIne is over in storage at the moment (no room at the inn, er, garage for everything) but I don't remember anything on the bottom to secure the unit.
And the roll bar windscreens just loosely snap in from the back.
-H. L. Mencken
09-14-2023, 06:45 PM
For reasonable prices and a huge selection of parts like this, eBay can't be beat.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-15-2023, 07:22 AM
Hardly.
09-15-2023, 01:01 PM
Thanks, PW.
Yes. My 2004 Base did not have any hardware. I bought the entire kit which included the three clips. My 2003 S had everything.
2003 Boxster S
09-18-2023, 04:31 AM
What confused me, is mine has the 2 clips at the top, but nothing at the bottom. I ordered a new set with all 3 and will install the bottom one.
09-22-2023, 08:46 AM
About 22 years ago, I was lucky to find and buy a Porsche Boxster clear center wind deflector for my 98 Boxster. I was the second owner and the original owner didn't have one when I bought his then 3 year old car.
Back then they could be had, all day long on eBay, for what at that time was a lot of money (about $50).......Times certainly have changed with prices now topping several hundred dollars!!
Now I'm trying to figure out ways to "lock-it down" because it's obviously such an easy target for thieves who know what they could cash it in for.
98' Boxster
09-23-2023, 05:34 PM
It should be pretty safe if you park with the roof up
Regards from Perth
Derek
09-25-2023, 06:45 PM
Hardly. .
Let me be clear. I buy most of my parts at Pelican, Suncoast, or Amazon. But if you're looking for something uncommon, such as a replacement belly pan (a.k.a. splash shield), headlight, taillight, wind deflector, etc., eBay is the place to go. Unless you're willing to part with an arm and a leg.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-25-2023, 08:00 PM
I have been curious, how does the shield come out? Mine seems very snug and so do the latches. I don't want to break anything.
09-28-2023, 06:50 AM
Best advice to to read your Owner's Manual.....it describes the "in's and out's of the wind deflector on your year.
98' Boxster
