Old 08-10-2023, 12:41 PM   #1
Center Wind Deflector
I want to add the wind deflector to my 986. I've seen used ones for $100ish or I can buy a whole new "kit" for $700ish (which I wouldn't do). The used ones I'm looking at have the rubber seal around the edge and appear to have some sort of clips at the top corners. Is that all I need to install one or are there other clips, pieces, etc., that I'd have to source?
Thanks,
E-
ecruz is offline   Reply With Quote
Old 08-10-2023, 01:14 PM   #2
randy328's Avatar
If you have never had one, you need the clips that go on the roll-bar.
https://www.pelicanparts.com/More_Info/98656132300.htm?pn=986-561-323-00-OEM&bc=c&SVSVSI=0789
2003 Boxster S
randy328 is offline   Reply With Quote
Old 09-12-2023, 09:22 AM   #3
I found a used wind deflector and my car had the 2 clips on the upper insides of the roll hoops, but it doesn't have a clip in the bottom/middle, either on the deflector or the car. There is a little ridge/indentation on the car, that the deflector seems to sit in. It clips in and seems secure. Is it safe to drive like this or is something missing?
Ridge/indentation
Pelican Parts shows 3 clips?
Old 09-12-2023, 11:40 AM   #4
1998 Boxster Silver/Red
After taking mine off for whatever... when reinstalling I slip it into that lower part then clicking into place the two top tabs. When it appears secure I give each top edge a pull towards the rear of the car to ensure it's snug.
Yours looks good. Go drive.
1998 Porsche Boxster
Old 09-12-2023, 12:23 PM   #5
Thanks! It seemed fine, I just didn't know why the Pelican kit has 3 clips.
Old 09-13-2023, 11:16 PM   #6
You absolutely need the center "clip" (lip).
Buy and install it, or buy it and another wind deflector later when you lose this one on the highway.
Old 09-14-2023, 03:39 AM   #7
Was the screen an option? Were 986s sold with zero screen hardware on the rollbar?
Thanks, PW.
Old 09-14-2023, 06:09 AM   #8
Thanks, PW.
For the plexiglass center windscreen, it has the 2 clips at the top, just not the one at the bottom/center. There is nothing inside the roll hoops for the "screens". Not sure if there should be something there or not.
Old 09-14-2023, 06:00 PM   #9
MIne is over in storage at the moment (no room at the inn, er, garage for everything) but I don't remember anything on the bottom to secure the unit.
And the roll bar windscreens just loosely snap in from the back.
-H. L. Mencken
Old 09-14-2023, 06:45 PM   #10
LoneWolfGal's Avatar
For reasonable prices and a huge selection of parts like this, eBay can't be beat.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
LoneWolfGal is offline   Reply With Quote
Old 09-15-2023, 07:22 AM   #11
Hardly.
Old 09-15-2023, 01:01 PM   #12
randy328's Avatar
Thanks, PW.
Yes. My 2004 Base did not have any hardware. I bought the entire kit which included the three clips. My 2003 S had everything.
2003 Boxster S
Old 09-18-2023, 04:31 AM   #13
What confused me, is mine has the 2 clips at the top, but nothing at the bottom. I ordered a new set with all 3 and will install the bottom one.
Old 09-22-2023, 08:46 AM   #14
Rob175's Avatar
About 22 years ago, I was lucky to find and buy a Porsche Boxster clear center wind deflector for my 98 Boxster. I was the second owner and the original owner didn't have one when I bought his then 3 year old car.
Back then they could be had, all day long on eBay, for what at that time was a lot of money (about $50).......Times certainly have changed with prices now topping several hundred dollars!!
Now I'm trying to figure out ways to "lock-it down" because it's obviously such an easy target for thieves who know what they could cash it in for.
98' Boxster
Old 09-23-2023, 05:34 PM   #15
It should be pretty safe if you park with the roof up
Regards from Perth
Derek
derekcohen is offline   Reply With Quote
Old 09-25-2023, 06:45 PM   #16
Hardly. .
Let me be clear. I buy most of my parts at Pelican, Suncoast, or Amazon. But if you're looking for something uncommon, such as a replacement belly pan (a.k.a. splash shield), headlight, taillight, wind deflector, etc., eBay is the place to go. Unless you're willing to part with an arm and a leg.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
Old 09-25-2023, 08:00 PM   #17
I have been curious, how does the shield come out? Mine seems very snug and so do the latches. I don't want to break anything.
wiebuschk is offline   Reply With Quote
Old 09-28-2023, 06:50 AM   #18
Rob175's Avatar
Best advice to to read your Owner's Manual.....it describes the "in's and out's of the wind deflector on your year.
98' Boxster
