Old 08-01-2023, 12:44 PM   #1
Should the purge valve leak at all
purge valve 996-605-203-01, under the left side manifold on 2000 S.
I removed it and applied vacuum, prior to opening the valve with a 9-volt, I observed that was was leaking down.
Is this a failure, I will report back to confirm it is opening correctly.
David
Luckyman01 is offline   Reply With Quote
