Old 07-18-2023, 04:16 PM   #1
JacquesB's Avatar
What's wrong with this window door
need help
sometime when my driver door is lock i unlock it pull the handle and the window drop like it suppose to (everything work fine for hours or day) but the next day or week i unlock the driver door and nothing ....no window down maybe for hours or days then everything come back to normal next day passenger door work perfect
thanks
JacquesB is offline   Reply With Quote
Old 07-18-2023, 06:30 PM   #2
KevinH1990's Avatar
There is a microswitch that controls the window drop. I had to replace the microswitch on my passenger door. It is possible you are experiencing the same issue.
These videos may be of assistance:
https://www.youtube.com/watch?v=lNnkMs4jjoM
https://www.youtube.com/watch?v=XowDhZmLqD8&t=505s
Old 07-19-2023, 08:31 AM   #3
JacquesB's Avatar
Thanks you open the door this week end
Old 07-19-2023, 07:27 PM   #4
elgyqc's Avatar
Salut Jacques, le problème peut aussi être les soudures à l'intérieur du "latch". C'était ça mon problème. Ou reste tu à Laval? Je suis à Pont-Viau...
#13 dans ce fil de discussion...
http://986forum.com/forums/boxster-general-discussions/78235-door-window-not-dropping-properly-%96-troubleshooting-check-list.html
Grant
Old 07-20-2023, 06:28 PM   #5
JacquesB's Avatar
Salut ELGYQC
je suis de fabreville
vendredi soir je vais ouvrir l'intérieur de la porte pour investiguer
