Old 02-07-2023, 01:01 PM   #1
Water behind the driver's seat.. Weird case
Hi Everyone,
I'm new here. Just bought 1998 2.5 986.
Before you all slap me in head and send out to read existing threads. Just FYI I did my homework.. All 6 drain holes checked.
Door bottoms checked. And the best part is water gets there even now on dry days.. Was thinking maybe coolant. But I'm not loosing it in the reservoir level indicator.. Level of coolant remain the same.. I can feel water gathering in the very corners of each side behind the seats.. Any suggestions?
Marcin
Keatn84 is offline   Reply With Quote
Old 02-07-2023, 03:44 PM   #2
elgyqc's Avatar
Behind the seats could be from the a rip in the foam liner that drains water into the rear drain holes. Also could be around the window. When I patched my rear window it was not properly sealed so water dripped onto the carpet near the roll-bar then worked its way down to the floor.
Grant
Old 02-08-2023, 07:06 AM   #3
seningen's Avatar
One trick to use is put some dry food coloring of different colors in a couple likely spots -- and hose down the car -- you can then look to see what color the water is.
mike@lonestarrpm.com
Old 02-08-2023, 03:53 PM   #4
barkinfool's Avatar
I'm betting on a rip in drain trays under the top. Good luck & let us know what you find.
Barkinfool
'02 Boxster S
barkinfool is offline   Reply With Quote
Old 02-17-2023, 09:55 AM   #5
98 Arctic silver 986
tommy583's Avatar
Are you sure it is getting wet on dry days? There is a lot of foam under the carpet. It takes a long time to dry out, like a long time. I've heard of guys taking the whole carpet out of the car and laying it in the sun for days before it actually totally dries.
If the drains are clear the next thing I would look at is the foam trays leading to the drains.
Old 02-17-2023, 01:08 PM   #6
Casual Driver
Have you checked to see if the small plastic gutter that clips along the back (used to drain water either left or right into the foam drains) hasn't unclipped? If it has, any water will seep behind the seats.
Porsche Boxster S 986 3.2 | Manual | Midnight Blue
jamesmartin986 is offline   Reply With Quote
Old 03-01-2023, 08:10 AM   #7
how do you fix the drain trays if they’re ripped?
2004 986s Carmona Red
bobaachaar is offline   Reply With Quote
Old 03-01-2023, 09:25 AM   #8
1998 Boxster Silver/Red
Thank you for the reminder. I've had "black caulk" on my list for weeks. SoCal weather has been favorable with the exception of snow and rain recently. Anyhow...
If the rips are too large, consider a replacement. If it is a slight perforation or tear... you might consider caulking it. I believe there is/are thread(s) upon this forum that may describe the process.
I'll be doing some reading myself, so that I purchase the proper product. Cheers.
1998 Porsche Boxster
Old 03-02-2023, 07:50 PM   #9
elgyqc's Avatar
I used "Goop" and a piece of clear plastic for a patch. Seems to be working a few years later. There may be a better adhesive, those trays are really fragile and as I remember they are expensive for what they are.
Grant
Old 03-08-2023, 05:23 PM   #10
Porsche "Purist"
Paul's Avatar
I used the brush on version of black Flex Seal to coat the entire foam areas.
1987 924S. 2002 996TT. PST-2
