Old 05-13-2021, 12:19 PM   #1
99 986 Stalling when A/C cuts on
Hello,
So I've done a ton of work to my Boxster but now have a new problem. It started when I replaced the charcoal canister and fuel vent valve. Car would start up and run perfectly but if I shut it off after it was hot it would have problems starting. I took it to mechanic and they diagnosed an air leak and corrected. I went to pick it up and it was perfect, until I turned on the A/C, then it stalled out. It seems as though my problems began when I was trying to chase down the evap leak and replaced those items, could they be causing the new issue? Thanks for the help
Boyantonwl is offline   Reply With Quote
Old 05-13-2021, 04:10 PM   #2
Originally Posted by Boyantonwl View Post
Hello,
My guess would be that a part you replaced is installed incorrectly.
Example: your fuel vent valve. My guess is that when the car was hot and you shut if off
The fuel vent valve allowed fuel vapors into the intake. Causing a to rich mixture for hot starting. Sorry to say but you may want to go back and double check all your work and any electrical connections.
Old 05-14-2021, 09:09 AM   #3
Thanks, I will take it apart again and double check, also got a new fuel filler vent valve to see if it was part of the issue.
