Old 04-26-2021, 07:17 PM   #1
Vza
Oil Switch
Hi,I've been running M1 0w-40 in my 99 Boxster with 135K plus miles. I track the car and was thinking of switching to Castrol Edge 5W-40 any thoughts ?
Thanks V
Vza is offline   Reply With Quote
Old 04-27-2021, 06:08 AM   #2
1998 Boxster Silver/Red
Thanks V
1998 Porsche Boxster
Old 04-27-2021, 06:34 AM   #3
Thanks V
What is your reasoning for making the switch? Getting an oil analysis done may be a good first step to get a baseline on your engine and oil.
driver8 is offline   Reply With Quote
Old 04-27-2021, 07:03 AM   #4
Thanks V
That's what I've been running in mine for the last 80k or so miles.
So far so good.
Old 04-27-2021, 05:59 PM   #5
Vza
No reason in particular. A few treads on running an oil a little heavier on the winter side. Although it's mostly in the garage for the winter. I do have a brief hi rev and noise on start up. I've read this normal for a boxster. And I do track it ...so maybe something for more protection. I did have the oil analyzed for a baseline. Does it have to be the same oil type if I do it again? V
Old 04-28-2021, 06:03 AM   #6
Thinking the high rev and noise might be the starter. Consider looking into it.
Old 04-29-2021, 06:12 AM   #7
You would want a few analysis using your current oil before switching, if you want to do a comparison of the analysis between the two oils.
If you want the best protection at the track, then you may want to look at a race oil, but the change intervals are much shorter.
Old 04-29-2021, 05:52 PM   #8
Artist, 986S tinkerer
NewArt's Avatar
In my opinion, the brand of oil is less important than the frequency of changes.
