Old 11-01-2006, 12:24 PM   #1
Window not adjusting when top down
I've noticed that my driver side window is up too high when I close my door with the top down (door wil not close). I recall it used to adjust automatically after the door was closed, but isn't doing that now. It does adjust when I open and shut the door a second time. I'm worried I might break the window. Anyone familiar with the problem and know a fix? Thanks. Much appreciated as usual.
amyandcarlos is offline   Reply With Quote
Old 11-01-2006, 12:59 PM   #2
Have you recently disconnected the battery? If so, the window lost it's standardization setting. Do a search and you'll find the procedure for resetting it. Hope this helps...
Happy Motoring!... Jim'99
Old 11-01-2006, 01:43 PM   #3
Thanks. I found a reset thread and will give it a try.
