Old 03-08-2021, 10:50 AM   #1
Shipping time for replacement key from dealership
Hey y’all, to those of you who have had a replacement key ordered from a dealership, how long did it take your dealership to get the key?
A_NeonTurtle is offline   Reply With Quote
Old 03-08-2021, 11:06 AM   #2
1997 Tip, 2018 Macan
rexcramer's Avatar
Next day and they need +/- 15 minutes to program the car when you pick it up.
Old 03-12-2021, 06:48 PM   #3
Are you needing the actual key or the fob? Most would have the fob on the shelf but the key comes from Germany.
Took 2 days about a month ago for one of my cars. Then the screwed it up and deleted all keys when adding my new fob
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 03-12-2021, 06:50 PM   #4
According to Gone in 60 seconds, stl is right and they have to be cut in Stuttgart
Old 03-12-2021, 06:54 PM   #5
Also suggest calling around to dealers or see if yours will price match other dealers. I ordered a fob & key from Silver Springs, they were cheaper then everyone. Then took it to the dealer to be programmed. Fob should run you under $150 & key should be under $60 (think it was much less can't remember). Less then 1 hour labor & your tow. I would get 2 keys if you can swing it.
the other option is to find a DME/Immobilizer with keys on ebay. That's what I did for my 2000 and it was under $300. I already had 2 keys but the fob buttons quit working some time ago. No programming necessary. You would still need the key blank, but any dealer can order that & ship it to you for you to put in the fob at home.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 03-13-2021, 06:00 AM   #6
So if you switch out one then you must switch all of them, right? If you need a new dme then you must buy it with the matching immo and keys? Or do the keys just sync with the immo and the dme can be swapped separately?
Old 03-13-2021, 06:15 AM   #7
rexcramer's Avatar
The keys can be had from other places than Germany/Porsche. keysinthepost.com are in England for instance. The key's transponder number needs to programmed into the car's memory so it is recognized as valid. This needs to be done with Porsche's proprietary system. Typically done at a dealer or a very high end indie shop. The OEM code reader system is very expensive.
Old 03-13-2021, 10:31 AM   #8
JayG's Avatar
If its done at an indie, they will need to get the Porsche security codes for your car
