Old 10-22-2006, 12:47 PM   #1
Rattle sound coming from exaust
Hello again! The other problem i have with my 97 boxster is a rattling sound from the exaust between 1000-2000 rpm. It doesnt seem to be getting any worse but its definately a problem. Any ideas of what it could be would be greatly appreciated. I get scared of being taken for a ride when i take the car to a garage and i just cant afford it right now! Thanks again. Andrew
drew900uk is offline   Reply With Quote
Old 10-22-2006, 01:35 PM   #2
I suspect that you have a heat shield which has loosened up. Porsche doesn't use the best fastening kit on these and so you should try and tighten all the bolts which secure the heat shields. I suspect this will end your issue. Hope this helps...
Happy Motoring!... Jim'99
Old 04-30-2007, 12:39 PM   #3
I have been having the same intermittent metallic rattle coming from teh outside underneath the car, 2 days after getting it from the dealer on a 2000 Boxster 2.7. Told the dealer over the phone and they reckon it might be the heat sheild coming loose. I cant get under the car despite being slim so might just take it to a garage and get it looked at!
any other ideas??
bedfordbox is offline   Reply With Quote
Old 04-30-2007, 12:46 PM   #4
rattling
front wheel bearings bere to blame, they cost a pittance but of course the labour was NOT. 250 odd quid is what it cost me. Best of luck
Old 04-30-2007, 12:53 PM   #5
"pittance" = small amount
"quid" = several thousand US Dollars
Hehe...
conradtan is offline   Reply With Quote
Old 05-03-2007, 01:55 AM   #6
I had the same rattling problem on my 2001 Boxster.It was the heat shields at the rear.There are three bolts holding each one on.If you lye down at the rear of your car and feel the heat sheilds you will see if they are loose.You may be able to tighten them but they usually rust around the bolts so you will need to replace them.
PMCHSS is offline   Reply With Quote
Old 05-03-2007, 11:06 AM   #7
I had a sound like that too, then after leaving the car running and looking at it from behind, I realized it was only the chrome exhaust tip. Mine seems to come loose from time to time. One bolt one each side. Check and make sure it's not that. Simple fix. But you will need a hex type tool or large allen key.
porsche986spyder is offline   Reply With Quote
