Old 07-24-2020, 08:13 PM   #1
2000 Boxster Tire Pressure
Just installed Continental Extreme Contact Sport Plus Tires on 17" Rims. My prior Bridgestone's were set to 29F and 36R pressure per the owner's manual. The Tech set the new tires at 34 F and R. The car is 20 years old and maybe there is a reason for the change in pressure. The car handles fine with the 34# pressure but not not driving hard during the recommended break in period. Any recommendations from those who have been driving their Boxsters. Thanks!
Commander is offline   Reply With Quote
Old 07-24-2020, 08:31 PM   #2
BYprodriver's Avatar
I would just drive it like that for a while and closely monitor tread wear. Lower air pressure to suit your preference for ride comfort &/or cornering gradually.
Having said that,I have known some great mechanics that know nothing about tires! I run 34 F & 35 R in my 2000 Box
Old 07-24-2020, 08:59 PM   #3
Qingdao's Avatar
35 psi is industry standard for new tire installs. Put them at the pressure you want for the driving you're gonna do. I run factory spec pressures on my boxcars. If I was to hit the track or something I suppose I'd lower them a lot. Highway driving raise them up.
'98 PP13B powered "RX986"
Qingdao is offline   Reply With Quote
Old 07-24-2020, 09:59 PM   #4
Racer Boy
Racer Boy's Avatar
You probably won't notice much difference in regular street driving. Porsche wanted the car to understeer so the average driver wouldn't spin the car, so they specified low pressure in the front tires.
Old 07-25-2020, 12:38 AM   #5
I tried F29 R34 (Michelin Pilot Sports) for some fast driving in twisties, and it really improved my MY99 2.7... previously I was running F34 R36
Riggsbie is offline   Reply With Quote
Old 07-25-2020, 01:59 PM   #6
Qingdao's Avatar
I thought dropping pressure in the front would give the tire more grab and decrease understeer?
Old 07-26-2020, 09:46 AM   #7
Racer Boy
Racer Boy's Avatar
Nope. At least not with street tires, with less pressure they roll over on the rim and you only use the outside edge of the tire, giving less grip. That equals understeer, which for most drivers is much safer. The Boxster from the factory came with little to no negative camber for this reason.
However, Porsche did build into the car the ability to change camber a bit. Not as much as some of us would like (those who track the car), but it's enough to make a sizeable difference.
