Old 07-21-2020, 07:42 AM   #1
BOOTLEG's Avatar
O-ring for clutch release guide tube
replacing clutch parts on 6 spd trans. This O-ring is ~56mm and the guide tube is only ~41mm... clearly a mis-match. Pelican had no explanation. JFP..HELP
BOOTLEG is offline   Reply With Quote
Old 07-21-2020, 08:20 AM   #2
A Porsche Guy
1PorscheBoxster986's Avatar
The diagram you show looks different than your picture of where the o-ring placement should be. Are you showing the throw-out bearing guide tube with the o ring? The part # you stated is the o ring for the guide sleeve which is part # 99611608701. I think that's where your problem is.
1PorscheBoxster986 is offline   Reply With Quote
Old 07-21-2020, 10:27 AM   #3
BOOTLEG's Avatar
Thanks 1Porsche...
Note your number is #7 in the diagram and the list. The diagram shows the O-ring is between the inside surface of that guide tube and the outer surface of the input shaft seal. My picture has the O-ring on the input shaft next to the shaft seal consistent with the diagram.
Here is a shot of the same O-ring on the inside surface of the guide tube I removed from my trans. My new guide tube is identical to my old one.
Old 07-21-2020, 11:11 AM   #4
Bootleg,
Take your old guide tube to a Napa auto parts store.
A counter parts person should be able to fix you up with the right size O-Ring.
Old 07-21-2020, 11:42 AM   #5
BOOTLEG's Avatar
there is no O-ring
It's actually easier than even that...Turns out that O-Ring is for the 5 speed. The 6 speed has no O-Ring which explains why I found none during my disassembly.
Old 07-21-2020, 01:27 PM   #6
The old automotive diagnostic adage rings true= simplest things first.
Glad you worked it out.
