Old 07-04-2020, 08:16 AM   #1
Front left turn indicator not working
2005 Boxster.
I've checked the bulb and it's fine (changed it just to be safe) but still nothing. The headlight works. All 3 of the other turn indicators work (front and rear right side and rear left). Hazards show the same issue -- only front left light is out. I checked the contacts on the lamp socket and the connection in the rear of the headlight module with a continuity checker and everything seems A-OK. The blades inside the socket seem to be fine.
Before I take it to a dealer for a more.. expensive.. diagnosis, is there something else I should check?
berjb is offline   Reply With Quote
Old 07-04-2020, 09:03 AM   #2
Keith Newby's Avatar
Hmmm...possibly an issue with the light switch?
Keith Newby is offline   Reply With Quote
Old 07-04-2020, 09:37 AM   #3
Where would I find that? Is it something easily accessible without pulling everything apart?
Old 07-04-2020, 02:13 PM   #4
1998 Boxster Silver/Red
If you've got power to the socket... start running through a few bulbs.
1998 Porsche Boxster
Old 07-04-2020, 07:31 PM   #5
gabedrummin's Avatar
I have had some turn signal issues in the past always ended up being a headlight not being seated properly . Check fuse ,,check bulb ,check for power at socket .
gabedrummin is offline   Reply With Quote
