Old 06-01-2020, 02:03 AM   #1
WALDMEISTER
BRAN's Avatar
DRL: Parking lights cable connection needed
Hi guys,
does anyone know, which color the parking light cable in the connector/harness (frunk, left side - standing in front of the car) has or can read the Bentley Manuals really good, that would be much appreciated
I have a pair of Hella LEDayFlex II and their IKEA style wiring diagram...
Ignition on = DRL on
headlights on = DRL off
TASK: I don't want to run any cables inside to the switch, relay or fuses = All cables should be attached in the frunk area.
QUESTION: parking lights cable = Can I find it in that harness and which color would it be (s. pic)
switched plus = black/yellow (I will use the one from the spray jets) and the rest is no problem.
THANK YOU,
Old 06-01-2020, 03:13 AM   #2
WALDMEISTER
BRAN's Avatar
Hi BRAN,
just a guess, but could it be the GR/RE cable (gray = parking light, red = plus)?
It would kind of match the left headlight (standing in front of the car) shown in the diagram & match the "gray" cable mentioned in the hella table above (58)?
Not an expert here.
Old 06-01-2020, 10:14 AM   #3
WALDMEISTER
BRAN's Avatar
Thank you, BRAN for your help!
I didded it!()
Look...it works as it should. A Little x-mas feeling in the frunk.
