Old 05-17-2020, 05:43 AM   #1
986 coolant flush broken impeller
my impeller broke, now there are shards in the system...what is the best way to flush it out? hose up the thermostat hose, do i have to pinch off the front radiator hoses first, then do them after the engine flush, can i leave the water pump off when i run the hose into the system...back flush? please, i love my boxster, and want to TRY to get all the junk out and SAVE it...please help
Tlightfo is offline   Reply With Quote
Old 05-17-2020, 06:02 AM   #2
1998 Boxster Silver/Red
Do some research and reading. Asking for help about something that has been discussed on this forum many, many times (do a search) may be met with silence. Did you Google the problem? You'll find plenty.
When you run into a challenge... can't quite "get it"... then you'll find all the help you need right here.
Good luck.
1998 Porsche Boxster
Old 05-17-2020, 07:16 AM   #3
Gjohn3707's Avatar
Welcome
http://986forum.com/forums/boxster-general-discussions/29522-water-pump-impeller-blades.html
2001 Seal Grey Boxster Base
Gjohn3707 is offline   Reply With Quote
Old 05-19-2020, 01:59 PM   #4
Subman's Avatar
FWIW, on my car the PO had replaced the water pump after the impeller failed. Last year we pulled the oil cooler that sits atop the engine to replace the o-rings, which were leaking oil. While it was off we looked in the water side of the cooler & found a bunch of plastic shards from the impeller. Makes sense since it's one of the most restrictive places the coolant must flow through.
2004 Boxster S - 50th Anniversary of the 550 Spyder
2000 Carrera Cabriolet
2016 BMW R1200R
1971 BMW R75/5
Subman is offline   Reply With Quote
