Old 04-12-2020, 06:27 AM   #1
new exhaust = too loud, any thoughts?
Hi, I finally got around to installing my new exhaust (been sitting in boxes for over a year) anyway its a full exhaust - catless headers, secondary cat delete pipe, c pipe & muffler. Its the typical cheap one you see all over ebay, I thing my brand was topspeed? everything fit great & its rock solid secure & no drone.
Problem is its just too damn loud when you get on it & at wide open throttle I can be heard for quite a distance. Its also a bit raspy & slightly higher pitched than i would like. Any ideas on how to tone it down a bit or tune the sound?
I was thinking of motorcycle exhaust baffle inserts to take the edge off, or even stuffing a stainless steel pot scrubber in there with the baffle. has anyone here tried that?
paulb is offline   Reply With Quote
Old 04-12-2020, 07:21 AM   #2
Conrats on your new exhaust!
In general I would hesitate to put something restrictive in the exhaust, since itīs kind of contradicting to the whole idea with a more open exhaust. Maybe weld in a resonator in the midpipe to tune it down just a notch?
Old 04-12-2020, 09:06 AM   #3
The easiest solution is to put the cat's back on - they act as a baffle! Start with the mid-pipes and see how that sounds. If still too loud, re-install the headers with cats. That might get it back to something socially acceptable and can be done pretty easily.
But remember, it might be darn near impossible to get a system that you can hear a low rpm's but that doesn't rattle nearby windows at high rpm. It's one big tradeoff.
Old 04-12-2020, 09:25 AM   #4
BYprodriver's Avatar
I would put the stock muffler back on for best power.
Old 04-13-2020, 09:03 AM   #5
Why? My dyno test data (before and after with no other changes) shows that the Top Speed cat back muffler increases power over the stock muffler (not by a lot but by a measurable amount none the less).
Old 04-13-2020, 10:31 AM   #6
That conflict's with Jake Raby's Dyno testing many years ago, maybe Top speed has gotten better over the years but I wouldn't think it would be worth changing.
Old 04-13-2020, 12:56 PM   #7
I have played around a little bit with baffles to tone down a twin can GHL muffler . I inserted them into the exhaust tips and the baffles were wrapped with exhaust fiberglass . It did help but not enough on my engine . I am currently running a stock S muffler with a simple exhaust bypass like the PSE , but again it is too loud . I have a Mille Miglia single can muffler that I think will respond well to the baffles that is my next experiment .
Old 04-13-2020, 02:46 PM   #8
edc
550 Anniversary
edc's Avatar
I also before and after dyno tested the cheapy eBay exhaust around 2012 and showed around +10bhp kicking in from around 3.5k rpm all the way to the red line.
Old 04-14-2020, 05:52 AM   #9
Horsepower is not my reason for switching out the exhaust. I'll never turn down a hp gain. But really if I wanted more hp I would be playing around with a V8. The appeal of the exhaust is mostly to reduce weight (this swap = about 50# lost & should balance well with pulling spare out of front) & make car more tossable & give it a more aggressive exhaust note. Well, it is more aggressive sounding . I've got some baffles coming but it sounds like that's pretty minimal, if thats not enough & i suspect it wont be I'll keep looking for just the right combo.
