04-06-2020, 08:45 PM
2003 Boxster S Aftermarket Nav?Sat Upgrade
I have a, new to me, 2003 Boxster S with the Bose system. Given that it is a 2003 MY car, it also has the MOST wiring system. I am looking to replace the single DIN unit in the car with a Double Din unit that has SAT, NAV, and Apple Car Play. I have done searches on here, Crutchfield and CAI and can't seem to find something that would work in my car. I am willing to replace the amp if necessary. Anyone else have experience in doing this upgrade?
Also, for those of you who may have installed a SAT radio antenna under the plastic cowling forward of the windshield, have you had problems in SAT radio reception with that location?
Harry
1970 911T Hot Rod
2003 Boxster S
2018 Macan S
2021 718 Spyder
04-07-2020, 03:29 PM
I cannot help with the MOST compatibility issue. I have a 2000 and that is from the "pre-most" era.
I expect a satellite radio antenna would work fine in the location you are considering. Check out this thread: XM Satellite Radio in Boxster - Pelican Parts Forums for another option.
04-07-2020, 04:26 PM
04-07-2020, 06:29 PM
04-07-2020, 06:53 PM
04-08-2020, 08:30 AM
Originally Posted by Smallblock454
Interesting. Looks like it is Europe only at this time, but I’m sure that will change given a bit more time.
Here’s Google’s attempt at translating the description:
Do you sometimes talk to your classic? He with you now.
Available soon from your Porsche partner: The Porsche Classic Communication Management Plus (PCCM Plus) for vehicles with a 2-DIN slot.
Your PCCM Plus combines timeless driving pleasure with pioneering technology. Even if you like to travel in the classic way and sometimes skip the time: it is definitely important to you to get to your destination easily, comfortably and without traffic jams. The new Porsche Classic Communication Management Plus supports you in this.
With its unique, original Porsche look including Porsche lettering, the PCCM Plus fits seamlessly into the interior. In addition to operation via a high-resolution 7-inch touch display with optimized display, modern functions such as DAB + (Europe), Apple CarPlay and GOOGLE  Android Auto are now embedded in the PCCM Plus. In addition, the PCCM Plus has additional onboard navigation with Porsche-specific points of interest (POI). The route is guided in 2D or 3D. The associated map material is provided via an external SD card, which can be ordered from your Porsche Classic Partner or the Porsche Center.
Media can be played back via an SD card, USB, AUX and Bluetooth  . With the PCCM Plus, Apple CarPlay and GOOGLE  Android Auto can also be used for media playback, navigation and telephony.
Note: Porsche Classic recommends having the installation done professionally by your Porsche partner.
Further information
For Europe only.
04-09-2020, 09:02 PM
Some more infos in the technical specs.
Also it seems that this unit definitely does support MOST-bus, which is a big plus for me.
04-09-2020, 09:04 PM
Bigger photo.
04-09-2020, 09:12 PM
I recently upgraded my '04 S with a double din unit that has all the things you want. It actually doesn't have built-in Nav, but it gets the feed from the phone via Apple CarPlay or Android Auto. I happen to think that's better than built-in Nav anyway -- no updates, better software. I got a Pioneer 2500 head unit and a Soundstream 5 ch amp. Yes, you have to change the amp. There's also a model 4500 that has a couple of more bells and whistles, but it's nearly double the price and wasn't worth it to me. There are also better amps than the Soundstream, but the Soundstream does a fine job. I didn't want to spend $4k on the audio for a $12k car.
As to your Q about the mounting of the Sat radio antenna, yes, I've experienced some reception issues with the cowl mounting where it cuts out in certain situations that my DD, which has Sat, never cuts out. I spoke to my audio guy and he's going to relocate it to the top of the windshield. Don't have results yet to report.
Here's a picture of my install:
2004 Boxster S, 6 spd, Triple Black
1986 944 Turbo (sold in 1988)
Since then, a 300ZX, a few BMW 3 Series, a few VW's
04-10-2020, 10:00 AM
BoxMann: I bought a Kenwood DDX6906 and all of the other parts from CAI. Like you, I am going to rely on my iPhone for Nav. However, being in the SW, I have had occasional problems with the iPhone losing reception (Verizon) and wished I had actual satellite capability. But I find that if I lay out my route within cell coverage and then eventually lose it that the Apple map will continue to plot my progress with the turns though the route 'grays' out from its usual blue color. I got lost once coming back from the Hill Country Rallye in Kerrville, TX and wished I had had the Garmin with me.
BTW, what is located just above the head unit? I have one of those pull out double cup holders in that space and was hoping that I could retain that with the new head unit installation.
Harry
1970 911T Hot Rod
2003 Boxster S
2018 Macan S
2021 718 Spyder
