Old 03-31-2020, 06:43 PM   #1
Aos
Hi guys - my experience has been with an 02, but now I have an 04 SE. I believe that an 04 has a different AOS than the 02. Seems like there is a significant difference in how it’s attached. The books all seem to focus on instructions for replacement and installation of the earlier version. Does anyone have any instructions (procedures) for the 04 or preferably does a video exist? Overall, is the later AOS considered to be an easier swap than the 02? Thanks!
David Preston
2008 Cayman S
por356c is offline   Reply With Quote
Old 04-02-2020, 07:39 PM   #2
You won't even need procedures! AOS on 03 and 04 cars is not a tough job at all. You do everything from the top. It may look a little daunting but everything is reachable.
Old 04-03-2020, 10:50 AM   #3
Thanks Dghii !
David Preston
2008 Cayman S
Old 04-03-2020, 06:48 PM   #4
The hose clamp removal tool is a big help, other than that, nothing out of the ordinary.
Old 04-05-2020, 05:40 PM   #5
What is the hose clamp removal tool? Thanks.
David Preston
2008 Cayman S
Old 04-05-2020, 07:05 PM   #6
Porsche "Purist"
Paul's Avatar
1987 924S. 2002 996TT. PST-2
Old 04-06-2020, 04:39 AM   #7
Newbie
+1 on getting the clamp tool. It definitely makes it easier.
Sent from my SM-G965U using Tapatalk
1998 Porsche Boxster Base - 2005 Volvo S60R AWD - 2003 Subaru Wrx Wagon - 2003 Jeep Wrangler Rubicon - 1992 Subaru Loyale Wagon w/4in Lift - 2004 Dodge Ram 2500
GLImages is offline   Reply With Quote
Old 04-06-2020, 05:29 AM   #8
husker boxster's Avatar
I got the factory clamp off w/o the tool, but it took a lot of work. Once off, I threw the clamp as far out of the garage as I could and replaced it with a normal screw-type clamp. Made future replacements much easier.
1989 928 S4 5 spd - black
Old 04-06-2020, 06:01 AM   #9
1998 Boxster Silver/Red
That ******************** clamp... dificult to "remove"... are you talking about the clamp at the bottom of the AOS? Why wouldn't you just cut that hose in half and remove the AOS tossing away the old clamp and the cut-in-half hose?
Or, are you reusing the old clamp and the old hose? Thought not.
Old 04-06-2020, 03:39 PM   #10
I'm referring to the clamp that's at the bottom of the hose that goes into the engine. I didn't cut the hose since I wanted to reuse it.
Old 04-06-2020, 04:29 PM   #11
Gotcha. That's the hose to which I was referring. They cost a few bucks.
I could tell mine was the original AOS because, at 14,500 miles when I received my car... and replaced the AOS... that hose melted like butter in my fingers when I went to remove it.
For the kinda PITA the procedure... I opted to drop a few extra bucks on that hose.
Cheers!
