Old 03-07-2020, 12:25 PM   #1
Zzorro's Avatar
Convertible top - Strange issue - video link - SOLVED
Posted in technical Chat. See there for more details.
https://youtu.be/57yfndEJDsY
98 Boxster - Ocean Blue metallic. Bringing it back to life and having fun doing it!
20 Harley Streetbob -
Zzorro is offline   Reply With Quote
Old 03-07-2020, 10:53 PM   #2
looks like the motor/gear is not engaging well
saw this on youtube also and maybe you can get an idea.
https://youtu.be/dRRddWmayJE
ndfrigi is offline   Reply With Quote
Old 03-08-2020, 08:57 AM   #3
Zzorro's Avatar
Thanks. Yup, watched that one and it was helpful. The gears seem to work, I did test them before linkages were connected to the top. Full range of motion with no bouncing or strange noises.
I believe something is telling the motor to stop and start. Perhaps the sensor behind the drivers side left shoulder. I'm going to play a bit more with that one, see if that has something to do with it.
Old 03-09-2020, 10:56 AM   #4
1998 Boxster Silver/Red
Have you tried swapping relays? Might be the culprit if everything else seems to be in order.
1998 Porsche Boxster
Old 03-11-2020, 07:31 AM   #5
Zzorro's Avatar
Good point. I'll have to check I guess. I'll report back.
Old 04-01-2020, 09:38 PM   #6
Zzorro's Avatar
Well I replaced the relay and still had the same issue.
So I decided to play with the sensor over my shoulder. I "pulled" and held it towards the front of the car ever so slightly and I had full range of movement. Opening and closing. So I guess I know what the issue is now!
Still have a bunch of things I need to set. And the roof movement is jerky. So I bet there is some alignment I need to do. But it's getting there.
Old 04-03-2020, 08:27 PM   #7
I used my social distancing time to pull my top transmission today. The passenger side plastic gear was cracked and split. I'm ordering new gears. I hope I can get the other side back in time. That is where the limit switch is and I can't find any alignment marks. Mine behaved a lot like that b
MrBen is offline   Reply With Quote
