02-17-2020, 08:49 PM
Rear Suspension Clunk/noise
I have two Boxsters .Both 986 . Both cars at around same mileage 140000kms. BOTH cars have the same clunk over bumps .... i describe it as a flat clunk / rattling sound . In pursuit of the sound i have replaced engine mount, Macpherson struts and various rubbers on anti-roll bar etc ....no luck ... this noise persists. Is it a common fault as both my cars and one more friend's car all
have this same sound . Is it the trailing arms and if so which one ? Hope you can assist ryokan.
02-18-2020, 09:39 AM
Racer Boy
What piper said!
02-18-2020, 03:13 PM
Re rear track arms
Agreed - very likely the track arms, and almost impossible to test short of just swapping them out.
I used the Vertex poly rebuilds on my 2001S and really have no complaints as compared to oem, although some have expressed some theoretical concerns in the past.
I have also heard the 987 track arms fit and work well. Does anyone know if they offer any advantage - real or theoretical - over the standard 986 version? I ask b/c I need to replace these soon on my 2004SE.
Thanks everybody for the collective wisdom.
02-19-2020, 06:19 AM
I have Cayman trailing arms on mine. Don't notice any difference.
1941 Dodge Luxury Liner Coupe
02-20-2020, 07:35 AM
Had the same issue on my 98 986 with 180k kms. Agree with everyone responses. Tuning forks will probably fix it.
I ended up doing the entire rear suspension seeing as I wanted to get it done anyways. Problem fixed!
Funny thing is that the tuning forks ball joints I removed look and "feel" fine. Anyways, problem solved.
98 Boxster - Ocean Blue metallic. Bringing it back to life and having fun doing it!
20 Harley Streetbob -
02-20-2020, 01:03 PM
Had the same issue and discovered a few bolts to the rear storage container were loose. But, it sounded like a suspension issue.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
02-20-2020, 06:06 PM
I've got the Cayman arms on my 986 boxster and just put a pair on my 2009 Cayman, TRW JTC1316 from Amazon, price fluctuates but I got the latest pair for $78 each I think [edit was $68 each, score! Currently $89]. Crazy :,-)
02-20-2020, 06:17 PM
WOW! Even at $89, that's $180/pair! F-in A man! Great price! I changed mine last year, though. Is there an equivalent substitute for the fronts?
I wonder why the site says they don't fit Boxsters, though.
02-21-2020, 09:22 AM
It's the 987 part # so my guess is Amazon doesn't know it's a match for 986. The part is very similar to the 986 part, bolt hole end to end it is the same length, the 987 part has a little more curve to it, maybe to give better clearance for the e-brake cable or maybe to give more clearance for bigger wheels?
02-21-2020, 02:16 PM
Thanks. My concern was if it would change the alignment/geometry, but if the bolt holes are exactly the same, then it shouldn't.
Like I said, I changed mine last year, but it's good to know there's a cheaper option if I should need them again.
