Old 02-15-2020, 02:28 PM   #1
Brian Minson's Avatar
Bad fuel pump or fuel regulator
Hey guys, my 2001 986S has been having trouble starting, once started it doesn't like to move when you give it some gas. I changed out the MAF, testing for an intake leak and still no change. Today I hooked up a fuel pressure regulator to my system and looks like about 25 psi or 1.7 bar is what the engine has. I pulled the vacuum line to the air regulator and it didn't change the pressure at all.
I haven't pulled the fuel pump relay to test it yet, but would you agree with me this is a fuel pump on its way out?
Here is a video of whats going on.
https://youtu.be/hddx5Ux1v4Y
Brian Minson is offline   Reply With Quote
Old 02-22-2020, 09:07 AM   #2
UPDATE: I pulled the fuel pump relay and jumped it running the pump for 30 seconds, grabbing fuel at the inlet before the fuel filter. 850 cc damn near on the mark!!! I went ahead and replaced the fuel pump relay just for good measure.
I then pulled the fuel return line and did the same test... almost BONE DRY!!! I guess I am going to get another fuel filter, as this all kinda started after I replaced the fuel filter a few weeks back.
Any suggestions?
Brian
Old 02-22-2020, 12:29 PM   #3
Zzorro's Avatar
Had intermittent issues with loss of power while driving. Never had issues starting it, would idle fine and "cruise" fine. But sometimes when I wanted to punch it it would bog down terribly but never stalled out. And the bogging would only happen intermittently, Maybe 30% of the time. Strange symptoms.
My 98 Boxster had ~170k km (~110k miles). I had already swapped out the MAF earlier after my durametric was showing some emissions system related codes.
Purchased a VDO unit on Rock Auto. There are way cheaper ones out there though. I didn't bother replacing the sending unit.
It seems to have corrected the issue. I will see how that works this summer.
On your video, sounds to me you have a pretty high pitched whine at idea compared to mine. Maybe that's your fuel pump begging for mercy? I had some noise that went away after my pump was swapped out. Confirming further that my pump needed to be changed.
Hope that helps out.
98 Boxster - Ocean Blue metallic. Bringing it back to life and having fun doing it!
20 Harley Streetbob -
Zzorro is offline   Reply With Quote
