Old 12-28-2019, 03:50 AM   #1
Top down
Send a message via Skype™ to Pastor T
986 2.7 resonance tube
986 Lovers; does anyone know when and why Porsche started putting 2 resonance tubes on the intake of the 2.7 engine. Most of the pics I see of the 2.7 have 1 resonance tube. Mine has 2. Even the Bently Manual shows only 1 tube. Perhaps the 2.5 has 1 and the 2.7 has 2. I'm confused when I see pics of the 2.7 with 1 tube.
every day is a great day when you are driving a Boxster
Pastor T is offline   Reply With Quote
Old 12-28-2019, 04:09 AM   #2
WALDMEISTER
BRAN's Avatar
Mine has also 2. Hmm, I have never seen a 2.7l with just one. 2.5l only, maybe?
Old 12-28-2019, 05:30 AM   #3
jcp
My '99 2.5 has only 1..... It is identical to the pic posted by pastor T.
jcp is offline   Reply With Quote
Old 12-28-2019, 05:54 AM   #4
piper6909's Avatar
Maybe the single tube are on the older cars. I see from Pastor T's post that the single tube versions have a cable-controlled throttle body, while the dual tube, and I presume newer, have electrical throttle control.
My 2002 2.7 has two tubes.
Old 12-28-2019, 07:17 AM   #5
Newbie
I thought all 2.7s came with the dual tube intakes.
In 2000, Porsche switched the 2.5L with cable throttle and single tube to the 2.7L with e-throttle and dual tubes (on base the models). 2000 is the first year for the 3.2L S model as well. Which uses the same dual tube intake as the 2.7L (if I'm not mistaken).
My guess is the pictures are of a 2.5L.
Sent from my SM-G965U using Tapatalk
1998 Porsche Boxster Base - 2005 Volvo S60R AWD - 2003 Subaru Wrx Wagon - 2003 Jeep Wrangler Rubicon - 1992 Subaru Loyale Wagon w/4in Lift - 2004 Dodge Ram 2500
GLImages is offline   Reply With Quote
Old 12-28-2019, 11:02 AM   #6
1998 Boxster Silver/Red
So... the questions are begged... and I submit them to the PROS on this forum:
If you're running a 2.5... can you swap the manifolds from a different engine to run the two tubes (from one)?
If affirmative... is there any improvement in performance?
I do see on the two-tuber that the throttle body slightly is offset... and that could pose a problem with the 2.5 throttle body angle.
Thank you, and Cheers!
Old 12-28-2019, 11:30 AM   #7
Artist, 986S tinkerer
NewArt's Avatar
There’s also the problem of the throttle cable vs electronic
Old 12-28-2019, 01:46 PM   #8
Hi Art,
So... no workaround?
Would the two-tube manifolds fit onto the 2.5?
Would there be a performance improvement?
Or... is it a "just not gonna happen" scenario?
I'm guessing that if it could be done, already it would have been.
Old 12-28-2019, 05:29 PM   #9
NewArt's Avatar
I’m afraid that I can’t really answer that question, not having had any experience precisely. However, my feeling is that it’s probably not worth the trouble. There are other simpler mods that can be done to increase the oomph, like an udp or better air flow/exhaust, etc.
