Old 12-11-2019, 05:31 PM   #1
Beelzy's Avatar
Uh Oh! What's leaking here in the front? (2004 base)
Hello all!
So, I have a '04 base and I have a leak that's hiding in the passenger side wheel well!
You can see in the pic, that there is a dark area from the fluid on the outer part of
wheel well that goes all the way around.
I can't tell if it's coolant (most likely) or oil? Is there an oil line running from the back to the front of the car? I was hoping for some insight before I remove the bumper, so I know what to expect. Thanks for reading
Beelzy is offline   Reply With Quote
Old 12-12-2019, 08:26 AM   #2
1997 Tip, 2018 Macan
rexcramer's Avatar
No oil lines that far forward. If its oily, then maybe A/C freon leak? Get a finger on it and give it the smell test. I suggest you pull the wheel and remove the fender liner first. That is a fairly easy DIY. Then pull the bumper next.
Also, get the factory PET parts catalog from Suncoast's website. It will have a page with an exploded diagram to help you sort it out. Let us know what you find.
Old 12-12-2019, 10:19 AM   #3
Is your window washer fluid reservoir located on that side?
Do you have headlight washers?
Could it be the heater core leaking?
Old 12-12-2019, 12:19 PM   #4
still plays with cars...
BoxsterSteve's Avatar
That looks to be the right side of the vehicle.
Washer reservoir resides in the left fender behind the tire.
OP, keep us posted...
Six speed 2000 Boxster S
Old 12-12-2019, 02:09 PM   #5
98 Arctic silver 986
tommy583's Avatar
I would think either anti-freeze or brake fluid. There isn't much else on that side beside the EVAP canister.
tommy583 is online now   Reply With Quote
Old 12-12-2019, 03:06 PM   #6
There's a joint in the AC system right above there. Could be that.
'97 - Silver (rebuilt/stripping)
'99 - Black (rebuilt/sold)
'01 S - Rainforest Green (daily)
'03 S - Orient Red (sold)
Fiddlebog is offline   Reply With Quote
Old 12-13-2019, 02:08 PM   #7
Beelzy's Avatar
Ok, not having the time yet to pull the fender panel, I have observed the fluid levels the last few days and have discerned that the leak must be AC refrigerant. I haven't turned the heater or ac on week and have seen no more traces of a leak. I plan to remove the panel this weekend to confirm, then I will post my observations.
Thanks to all who replied, this forum and it's members ROCK! 👍
Old 04-13-2024, 05:35 AM   #8
Originally Posted by Beelzy View Post
Hello all!
Sooooo, what was the leak from and how did you repair it?
Tyson87 is offline   Reply With Quote
Old 04-17-2024, 04:35 PM   #9
Beelzy's Avatar
There is a rubber coolant tube behind the front wheel that was periodically leaking at the plastic connector to it.
