Old 08-24-2019, 07:45 AM   #1
Lucas oil additive
Anyone ever used Lucas ,or other brand, oil additive to cure, or help, rattling chain tensioner? Just curious. Thanks all
Tmar04 is offline   Reply With Quote
Old 08-24-2019, 07:56 AM   #2
I've used Marvel Mystery Oil to quiet a sticky lifter (when I replaced my 01 motor.) It took care of the lifter well.
2001 Boxster
2007 Toyota Highlander
Old 08-24-2019, 09:14 AM   #3
piper6909's Avatar
Are you sure it's one of the tensioners making noise?
If it is, from what I understand tensioners are easy to replace. I wouldn't take any chances with some additive. If the tensioner gets worse, it could allow the chain to skip time and then you're looking at some serious issues.
Old 08-24-2019, 09:29 AM   #4
Lucas oil additive
No, therein lies the problem. Don’t know fir sure. 88k miles, Mobil 1 FS 0w40 every 5k, car driven by responsible adult since new. Shouldn’t have internal engine problems But, noise is only for 1-2 seconds and not real noisy, just enough to get your attention. I’ll get it checked by Indie . Thanks so much y
Old 08-26-2019, 10:42 AM   #5
I too have used MMO for years. First on a '69 MGB all the way through to the Boxster. I started using to quite some lifters and simply continued. I remove about a quart of oil at 3,000 miles and replace with a quart of MMO. I run it for another 500 miles and then do a complete oil change. I posted my last oil/engine analysis on the "What did you do with your Boxster today" thread so check out my improvement over time. Have never used Lucas or any other additive.
A lot of people will claim it's snake oil but I also have the link where Jake Raby talks about how he has saved many an engine using MMO which was a good enough recommendation for me. So far...so good.
Jgkram is offline   Reply With Quote
