Old 05-28-2019, 04:17 PM   #1
Easy question - Mass Air Sensor screw
Does anyone know the part number for the two screws that hold the mass air sensor down for a 2001 Boxster? I dropped one into the abyss and need to replace it.
Also if you know an online source for these screws it would be much appreciated.
Thanks in advance for any help!
2001 Boxster - savanna on black
1960 MGA
http://i8.photobucket.com/albums/a18...7/mgaside2.jpg
impboy is offline   Reply With Quote
Old 05-28-2019, 04:51 PM   #2
Need For Speed
KRAM36's Avatar
The part number for the screw is 99991916007
2003 Boxster S
Old 05-28-2019, 05:09 PM   #3
Keith Newby's Avatar
I'm not quite sure what those screws look like but Marshalls Hardwar in Miramar stocks just about anything you'd need.
Keith Newby is offline   Reply With Quote
Old 05-28-2019, 05:51 PM   #4
Need For Speed
KRAM36's Avatar
This is what the screw looks like.
2003 Boxster S
Old 05-28-2019, 06:38 PM   #5
Do yourself a favor and take the remaining screw to the hardware store to find standard Phillips replacements.
Old 05-28-2019, 06:57 PM   #6
Will there be cake?
tonythetiger's Avatar
do a torx, but bypass the security torx, just easier. anybody able to share the size? Im doing a MAF next weekend and plan on replacing these with standard torx, even though I have the security drivers.
Old 05-28-2019, 08:44 PM   #7
Who's askin'?
maytag's Avatar
Note that this is a 6- point TR torx, whereas the screw holding the maf on my '03 S is (was) actually a 5-point TR torx. Seriously? Why would ANYONE do that?
Standard torx is fine. Sorry I don't recall the size.
Old 05-28-2019, 09:28 PM   #8
Need For Speed
KRAM36's Avatar
Interesting, on my 03 Boxster S, it's a 6 point TR torx screw. The torx bit I used has CR-VT20 on it.
2003 Boxster S
Old 05-29-2019, 05:07 AM   #9
husker boxster's Avatar
I agree with others who suggest replacing with a reg torx or phillips head.
But for those reading this thread who are having trouble getting the screws off, I took a Dremel to them, cut a channel thru them, and removed them with a reg screwdriver.
1989 928 S4 5 spd - black
Old 05-29-2019, 07:50 AM   #10
BYprodriver's Avatar
If you do that you might as well throw away the tool you bought to remove the oe screws.
