Old 04-18-2019, 03:31 AM   #1
noisy idle noise - "diesel" like sound
Hello again to this great community!
I decided to write here for an issue im having lately. My 2.7 (2003) boxster engine is doing a "knocking" sound on idle.
About the noise:
- Almost Irrelevant if warm-cold engine.
- It Reminds me of a diesel engine car sound ( )
- No CEL or anything related, spark plugs/coils/oil new
Only thing im a bit guilty is that the sound started happening when i switched to 95 Octane, but maybe its irrelevant ?
No idea of the Serpentine belt condition by the way.
Thanks to All!
Lacostas is online now   Reply With Quote
Old 04-18-2019, 08:48 AM   #2
01101
My water pump sounded like you describe when the bearing started to go. Pull your belt off and check the WP.
alm001 is offline   Reply With Quote
Old 04-18-2019, 11:41 AM   #3
Perhaps lifter knocking
My CS developed a lifter noise while idling and a friend of mine (Porsche specialized shop) suggested to try Liqui Moly "hydraulic lifter additive" which I used on the next oil change (LM 5-W40) and it helped a lot to reduce the lifter noise, you may want to try it.
Old 04-18-2019, 03:07 PM   #4
I had the “diesel” noise late autumn/early spring - extremely annoying sound. Proved to be the servopump and the generator making noises at idle. I did not do the replacements myself but according to my independent technician it was not a straightforward job.
Mine is 2003 S with 190.000 km on the clock - now spinning like a cat again.
2003 Boxster S
Seal Grey
Bruich10 is offline   Reply With Quote
Old 04-19-2019, 08:42 AM   #5
Beelzy's Avatar
Sounds like the water pump. Mine made the same noise right before it started
dumping coolant.
Beelzy is online now   Reply With Quote
Old 04-19-2019, 09:25 AM   #6
Have u tried opening the engine access behind the seats? try to use a plastic tube and use it to hear each part of the engine where the noise/sound is coming from.
Water pump, idler pulleys, alternator, power steering and AC motor.
ndfrigi is offline   Reply With Quote
Old 04-19-2019, 10:10 AM   #7
My waterpump went down 5 years ago at about 125.000 km - sound maybe similar but much more aggressive - and if the sound came “lately” it does not correspond with my wp experience.
Mine was: Sound - leak - wp bonkers!
But of course it is worth checking everything,
2003 Boxster S
Seal Grey
