Old 03-16-2019, 03:42 AM   #1
JBauer's Avatar
Replacement headlight seal/ gasket
This maybe common knowledge but I thought I share it anyway. My headlight seals/gaskets were old and deteriorated. Did some searching and wasn't finding much. Finally I came across an old thread on another forum and thought I'd try it. Here are the results
Thus seal:
https://www.mcmaster.com/1129a992
Looks like this:
Sticks like this:
and you end up with this:
Old 03-16-2019, 03:53 AM   #2
Good tip I'm sure there are a lot of old gooey gaskets out there in need of replacement . I was lucky to purchase a used set of OEM gaskets in perfect condition so for now I'm set .
rfuerst911sc is online now   Reply With Quote
Old 03-16-2019, 05:26 AM   #3
JBauer's Avatar
Where did you find those? 😲
Old 03-16-2019, 06:35 AM   #4
There Is No Substitute.
rick3000's Avatar
Great info, for some reason Porsche does not sell the seals separately even though they have their own part number.
Old 03-16-2019, 07:18 AM   #5
looks good, how many feet of the seal did you need to do both lights?
dav9515 is offline   Reply With Quote
Old 03-16-2019, 07:41 AM   #6
JBauer's Avatar
I bought a 5ft roll and have some left over.
Old 03-16-2019, 08:30 AM   #7
Thanks for this. You must be a mind reader, as I was looking at my messy old gaskets yesterday and wondering what to do with them!
robdelorenzo is offline   Reply With Quote
Old 03-16-2019, 09:09 AM   #8
JBauer's Avatar
LOL mine were OK but brittle and shrunk up. I replaced them with these. They look good IMO. I'll save the old ones.
Old 03-17-2019, 04:49 AM   #9
Just happened to find a local set from a forum member .......... a one in a million shot
Old 03-19-2019, 09:59 AM   #10
flouese's Avatar
Will this work for the tail lights?
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 03-20-2019, 01:41 PM   #11
hood gasket
I dunno.
I am needing the gasket / trim seal for the hood. Mine was all brittle and just flaked away. I can't locate that piece either. I guess mcmaster is a good place to start
Black Knight is offline   Reply With Quote
Old 03-20-2019, 01:52 PM   #12
JBauer's Avatar
I don't know but they have diff sizes. You might measure one and see if they have anything thst would work.
Old 03-21-2019, 06:35 AM   #13
Thanks for this. I ordered some and it arrives today. Gooey washers that are spreading black gunk and streaks are going away. Problem solved for $15.00. Now on to the next project....
Old 03-21-2019, 09:57 AM   #14
JBauer's Avatar
Great, let me know how it works out. Make sure you clean the edge of the light where it will be sticking to. I forgot the first time ��
Also make the rubber a little longer than needed, then trim once its locked in. If any parts are sticking out from locking the headlight in they can be worked level will a thin piece of plastic edge or your finger. After it was clamped awhile it sticks pretty well incase you need to remove the light. Good luck.
Old 03-21-2019, 12:35 PM   #15
JBauer's Avatar
I finished mine but forgot to post pics. Incase anyone is curious.
Still need to tuck it here and there.
Old 03-21-2019, 05:40 PM   #16
Thanks, I ordered mine and it is already here.
Joe K. Peachtree City GA
2001 986 Boxster S, Silver with black interior.
blueflames is offline   Reply With Quote
Old 04-16-2019, 09:42 AM   #17
Will there be cake?
tonythetiger's Avatar
awesome...ordered! what did you use to hold in place? glue?
Old 04-16-2019, 11:06 AM   #18
JBauer's Avatar
It has double side tape installed on it. Shown in thread 👇
Old 04-18-2019, 08:28 AM   #19
Will there be cake?
this arrived at my house in under 24 hours, enough for both cars and under 25 bucks. Amazed.
Old 12-03-2019, 10:22 PM   #20
GustaGo's Avatar
Thank you JBauer! I ordered and installed mine just last weekend, and now my headlights look great!
2004 Boxster base - Black (weekender!)
2017 Toyota Tacoma - Magnetic Gray
2017 Infiniti QX50 - Black
2022 Polestar 2 - Void… Black (Daily driver)
GustaGo is offline   Reply With Quote
