Old 09-17-2006, 03:11 PM   #1
How to change the air filter (DIY)
Anyone knows how to access and change the air filter? The cabine filter is done bu t could not find the air filter...thanks!
Thanks for your time,
Vanessa
99 silver Bosxter
99 silver BMW 323i
http://i105.photobucket.com/albums/m...rscheseule.jpg
vouvoune is offline   Reply With Quote
Old 09-17-2006, 03:34 PM   #2
ohioboxster's Avatar
You just have to put the top in service mode and the filter is on the left hand or drivers side. Do you know how to put the car in service mode? If not do a search it has been covered a bunch of times.
2002 TT
Old 09-18-2006, 09:37 AM   #3
Could you please be more specific? Through where do I access it...I was looking for it but could not find it where I was looking...
Vanessa
99 silver Bosxter
99 silver BMW 323i
Old 09-18-2006, 09:51 AM   #4
Look at the white sticker in the top of the picture. The air filter is under there. Release 2 metal clips and pull the filter out.
Old 09-18-2006, 09:59 AM   #5
Smile
Vanessa, don't worry if you haven't seen your engine...neither have I.
Norminhouston is offline   Reply With Quote
Old 09-18-2006, 01:34 PM   #6
Its a small process to "see the engine"
i would search for detail instructions on how to do this, try going to renntech.org, they have alot of write-ups on stufff like that.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 09-18-2006, 01:35 PM   #7
Hey your throttle body looks different than mine...yours is pointing at an angle, and doesnt look as wide as mine...Also i dont see a throttle cable on the passenger side of it like mine has.
Carlos J Cazares
Old 09-18-2006, 03:23 PM   #8
That is because the above picture is an egas car.
Here is a non egas 2.5.
Old 09-18-2006, 03:56 PM   #9
hey thats what mine looks like! I figured that was the difference.
Carlos J Cazares
Old 09-18-2006, 03:58 PM   #10
blkboxster
Posts: n/a
whats egas?
and what do i have on my 2.5
Old 09-18-2006, 04:02 PM   #11
And heres supercharged
2002 TT
Old 09-18-2006, 04:38 PM   #12
blkboxster
Posts: n/a
all these pictures made me wanna look at my engine.....
Old 09-18-2006, 04:47 PM   #13
Sent you a PM.
Hope that helps.
derb is offline   Reply With Quote
Old 09-19-2006, 10:23 AM   #14
deliriousga's Avatar
Originally Posted by blkboxster
whats egas?
Electronic Gas pedal. The pedal has a cable that goes to an electronic box rather than pulling directly on the throttle. When you push the pedal, it puls on a spring loaded pulley (just like the one on regular engines at the throttle body). The box sends a signal to the computer with how much gas you are giving the car and the computer opens the throttle body accordingly.
1966 Wife White/Brown Top
