Old 10-07-2018, 05:20 PM   #1
Suspension Noise
Need help/opinions. When the car is cold (1st start in the morning or at lunch)I get a pronounced clunk from the front end when I press the brake pedal. I can hear and feel it in the brake pedal. It only happens when I am backing up not moving forward. Once warmed up or moving at speed it doesn’t happen. What portion of the suspension needs to be looked at/replaced? As always, thanks.
Jgkram is offline   Reply With Quote
Old 10-07-2018, 05:57 PM   #2
Racer Boy
Racer Boy's Avatar
I'd take a look at the front pads. Do they have a lot of slop in them, as they can move around in the caliper front-to-back? If that is the case, there is your problem. Some pads come with shims that fit over the ends of the pads to address this very issue. If they are missing or damaged, you'll hear the pad clunk sometimes. When going forwards, the pads are always against the caliper because the rotation of the rotors pulls the pads forward in the caliper. That is why you would hear it when backing up.
Old 10-08-2018, 10:11 AM   #3
FoFoJoe
FoFoJoe's Avatar
I've heard this from my own pads, what I read confirmed what you said. The pads are shifting forward/backward by just a little.
2001 Base 2.7l, 5-speed (124k) - LN IMS kit
- TopSpeedAuto exhaust (headers/mid/muffler)
- 997 Carrera III wheels w/ECS spacers 18x8 +15mm/18x10 +18mm, Eibach springs
- FunctionFirst shift knob/short shift kit
- Focal speakers/Alpine amp/Kenwood deck/Pioneer 8" subs
FoFoJoe is offline   Reply With Quote
Old 10-08-2018, 02:12 PM   #4
Thanks guys. Believe it or not I do search the forum but I had no idea that pads could make this much noise which is why I kind of discounted it to begin with. I will take a look at them this weekend. I assume that I just pull the wheel and then try to shift the pads around by hand. Any significant play means this could be the issue. If so, how do i correct it? They still have wear left on them. Thanks again for the responses.
