Boxster General Discussions
Cooling fans
09-15-2018, 12:21 PM
gabedrummin
gabedrummin's Garage
Samantha
Cooling fans
What triggers the cooling fan relay to kick the fans on? My left fan is not comming on and the fuse is good and so are all the relays .Checked both fuses and all 4 relays.? Thank you all ..!
09-15-2018, 12:30 PM
2
particlewave
particlewave's Garage
F=ma
Engine temperature.
Use a jumper at the relay socket. This will tell you if it's a relay signal issue or if the problem lies in the wiring or fan itself.
09-15-2018, 12:34 PM
3
particlewave
F=ma
Jump between pins 30 and 87, like this:
09-15-2018, 01:46 PM
4
thom4782
if the left high speed fan works, but the low speed one doesn't, then the most likely culprit is the ballast resistor.
'87 951
'01S 986 (Sold after 16 years ownership)
'78 924 (carburated; sold when moving to CA)
Linear Mode
Switch to Threaded Mode
08:29 PM
