Old 09-09-2018, 11:10 PM   #1
Brake light works - Tail lights don't
Grrrr.....
So after replacing some burnt out bulbs in my tail lights, I went to put the tail light bulb holder back into its spot. Only one problem - I did it with the lights still on so when I touched the metal connectors of the bulb holder to the metal edge of the car, the smallest bulb on the end blew out and now all I have is a brake light on the drivers side and no tail lights. A hard lesson to learn but now what? Replace the bulb holder? I checked the fuses that go to the brake and tail lights and they were all fine. I replaced the burnt out bulb with a new one and that didn't help either. I'm sure I shorted out the system somewhere although I don't know why the brake light would still work.
Any help would be much appreciated!
2001 Boxster - savanna on black
1960 MGA
http://i8.photobucket.com/albums/a18...7/mgaside2.jpg
impboy is offline   Reply With Quote
Old 09-10-2018, 05:44 AM   #2
1998 Boxster Silver/Red
Is the side marker light illuminated when the lights are on. Had a similar problem a while back... fuses fine... bulbs fine... checked the sidemarker... wasn't illuminated... replaced the bulb... fixed it.
Worth a look.
1998 Porsche Boxster
Old 09-10-2018, 11:07 PM   #3
Hey Starter986!
Thanks so much for the advice. I did check the side light and it was out so I replaced it. Then, for no reason except to be certain, I check every single fuse and the side light fuse was also blown. So I replaced that and now everything is fine!:dance:
You called it right! Many thanks again.
1960 MGA
Old 09-16-2018, 09:07 AM   #4
Originally Posted by impboy View Post
Hey Starter986!
Awesome! Glad it worked!:dance:
