Old 06-16-2018, 03:30 AM   #1
Short-shifter adjustment assistance needed
As I’ve got some end-to-end play in my short shifter (B&M) and figured I’d tighten it—
I just can’t seem to get enough clearance to insert the hex into the end of the thread set screw—do I really need to remove the center console or is there a trick?
Attaching photos does not seem to work at the moment, will see if I can upload somewhere else.
square-root is offline   Reply With Quote
Old 06-16-2018, 06:46 AM   #2
Hmmm, tried to upload the image here:
Old 06-16-2018, 08:06 AM   #3
1998 Boxster Owner
I just cut out some of the plastic on mine. Now adjustment is quick and easy no fuss. If I had to do it again I would use a Dremel and keep a vacuum handy.
Benitom is offline   Reply With Quote
Old 06-16-2018, 11:01 AM   #4
Hmmm, that did cross my mind. Making a cutout for tightening will be rather non-obtrusive, and will be hidden by the shifter boot.
Unless anyone else has any ideas I'll go ahead and start cutting up my center console ;D
Old 06-19-2018, 06:46 AM   #5
UPDATE: The weirdest thing: I trimmed away the plastic that was getting in the way, but I just can't seem to adjust it anyway? There is about 1-2mm play laterally in the frontmost bushing, but it doesn't seem to want to have anymore tension. What have I missed?
Old 06-19-2018, 01:42 PM   #6
Did you put the washer-looking spacer in between the bearing/cup and the shifter stub? I have Ben's shifter and it includes this - not sure if your kit does too. Ben used to have you use a penny as a spacer, now he includes a metal spacer for the same purpose. Again, not sure about your kit, that's all I can think of.
Doug427 is offline   Reply With Quote
Old 06-20-2018, 12:09 PM   #7
Thanks Doug!
I did solve the problem, it was just me making the wrong assumptions. Shifter now has 0 lateral play and the "bolt rifle action feel" is back
