Old 05-17-2018, 10:48 PM   #1
Pdwight's Avatar
Parked for a while....water pump, But I have a question
I am at 80K miles, the water pump has a squeak...so time for a replacement. I have a genuine OEM pump and belt on hand along with a low temp thermostat....now to find the time;
Now to the question, Have most of you replaced the Tensioner/ Idler Pulleys when you do this ??
Thanks in Advance
Dwight
Old 05-18-2018, 01:26 AM   #2
still plays with cars...
BoxsterSteve's Avatar
At 80k you could just replace them for peace of mind while you have it apart.
Might just save you a breakdown later on.
Six speed 2000 Boxster S
Old 05-18-2018, 04:35 AM   #3
kk2002s's Avatar
I didn't at WP/Thermo maintenance replacement around 85k.
BUT around 90k I replaced all pulleys as one started squealing/grinding
Seal Grey
Old 05-18-2018, 05:08 AM   #4
Do a coolant flush too, at the same time. You need about 3 gallons of Porsche coolant and 3 gallons of distilled water.
Old 05-18-2018, 06:41 AM   #5
Racer Boy
Racer Boy's Avatar
When I replaced my alternator, I took the tensioner apart and greased the bearing. It needed it!
The grease seal can be removed if you carefully use a dental pick or something similar to pry it out of the bearing.
