Old 05-16-2018, 05:53 AM   #1
Rear right noise
I'm back to this problem again. I have a noise in the back right side that occurs when I am moving and I hit bumps in the road. Occurs when car is cold and then goes away once warm. It's not a loud bang, more a soft rattle (if this makes any sense). I tried pelican thinking I would give you guys a break. Not so much luck thus far.
Thanks,
David
DWBOX2000 is online now   Reply With Quote
Old 05-16-2018, 09:21 AM   #2
I had the same problem. As long as everything is tight Ie: muffler etc I replaced the rear track arms and drop links. They are wear items. That solved the problem.
Blackcloud is offline   Reply With Quote
Old 05-16-2018, 09:31 AM   #3
So the noise would go away when the car warmed up? Thanks for responding.
Old 05-16-2018, 03:56 PM   #4
What's the drop link in the back? What other name is it called?
Old 05-16-2018, 05:01 PM   #5
Sway bar link
Htci is offline   Reply With Quote
Old 05-16-2018, 05:47 PM   #6
Also called stabilizer link.
Old 05-16-2018, 06:59 PM   #7
Oggie's Avatar
Examples: https://www.pelicanparts.com/catalog/SuperCat/1043/POR_1043_SUSSHK_pg5.htm#item22
'99 base Boxster (Arena Red Metallic/Savanna Beige)
'02 911 Carerra Cabriolet (Arctic Silver/Metropole Blue)
Oggie is offline   Reply With Quote
Old 05-17-2018, 06:42 AM   #8
Gotch ya. I will re torque and see what happens.
Also, do those items expand as you drive? Wondering why the noise would go away when the car warms up. Never realized suspension units get warm.
Thanks,
David
Old 05-17-2018, 08:22 AM   #9
The Radium King's Avatar
also may be as simple as the head shield on the transmission shifter links - it is located on the rear right of the transmission where the shifter cables attach. it is held on by two small nuts and is designed to shield the shift mechanism from the exhaust. it gets loose and can rattle around.
