Old 04-13-2018, 02:40 PM   #1
SC-986's Avatar
Oil Cooler R&R/Coolant Drain
Getting ready to replace the original oil cooler on my '02 base with the "S" model cooler. Pretty straight forward procedure. My question is this - how much coolant needs to be drained to bring the level below the cooler and is it possible to remove that amount without draining the whole system?
2002 Boxster base - Seal Grey, 5spd trans.,ROW M030 upgrade, FVD Brombacher software tune
2004 550 Spyder Anniversary Edition, #1541,Tip, TechnoFix DOF IMSB upgrade
SC-986 is offline   Reply With Quote
Old 04-13-2018, 04:00 PM   #2
1997 Tip, 2018 Macan
rexcramer's Avatar
I think you will find that you can't just drain coolant out of the oil cooler/engine. When you pull the drain plug and or hose, fluid will drain from everything equally. I just flushed my system and that is my experience.
If you drain into a clean container, you can refill with what came out. You might do a visual and strain it as you put it back in. Also, note that the drain plug has a crush washer under it that should be replaced and torqued to 7-11 ft lbs. Think oil drain plug but smaller. Verify by your year/car.
After thought, I suppose you could try pinching off the the three hoses with clamps that go into the block. I always thought that might weaken/damage them.
Old 04-13-2018, 05:16 PM   #3
As soon as you lift the old cooler off of its O-rings, push a plastic bag under it to catch fluid. I drained a lot from the normal spots underneath and still had a lot spill.
clickman is online now   Reply With Quote
Old 04-13-2018, 05:26 PM   #4
jsceash's Avatar
It's a good time to replace the oil. You can't stop some water from getting into the oil. I've done it twice and got water into the oil both times.
Old 04-13-2018, 06:36 PM   #5
SC-986's Avatar
Good point - I was going to drop the sump plate at some point and install an EBS baffle. Good time to do that.
Old 04-13-2018, 11:18 PM   #6
I did the Pelican kit for my baffle upgrade. For the $$$ it’s excellent and has all the goodies. Proper sealant for tray being one of them!
