Old 03-17-2018, 09:37 AM   #1
18’s to 17’s
Anyone ever switch a set of 18” twist to 17” wheels? I have an 01 S with 18” twists, my friend is selling some 17” Fikse fm10 Wheel's & new tires. I need new tires, since my alignment was off. These are fairly new tires and nice rims, but what would the size change do to the handling of the car?
Steelepuls is offline   Reply With Quote
Old 03-17-2018, 10:09 AM   #2
Ciao's Avatar
I switched 18" turbos to 17" turbos but did not ride on the 18s. I decided 17s are better in terms of handling, weight, performance, and more options in tire sizes
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 03-17-2018, 10:40 AM   #3
BYprodriver's Avatar
If the height of the tire doesn't increase you may notice better performance since the Fikse's will be lighter.
Old 03-17-2018, 06:08 PM   #4
My car came with 18 inch wheels and I picked up a set of 17 inch factory wheels. On the street I would say there’s no difference in handling, but the extra half inch of sidewall rubber makes the ride a touch smoother.
Old 03-18-2018, 12:38 PM   #5
Track rat
Topless's Avatar
Effectively zero difference in handling if running similar tire compounds. 17s offer a touch smoother ride and tires cost less $$$. 18's allow you to run wider tires. I have run both sizes over the last 13 years and each has it's purpose.
Old 03-18-2018, 05:45 PM   #6
Thanks for the input guys. I think I will try the 17s. I do a lot of commute driving, so smoother is a great benefit, and if there is a tire selection plus saving $$ is included, I’m in.:dance:
Old 03-18-2018, 08:06 PM   #7
It’s lighter in many cases too.
