Old 01-26-2018, 09:25 AM   #2
BobRickel's Avatar
The microswitch located on the header panel probably needs to be replaced or adjusted. When you hit the bumps the body flexes and loses contact with the switch. The car thinks that the latch has been loosened and it drops the windows in preparation for the top being lowered. Sometimes you can bend the contact on the microswitch to increase contact with the latch.
BobRickel is offline   Reply With Quote
Tags
problem , top , windows not working
