Old 01-23-2018, 12:46 PM   #1
Goth Popper
99 Boxcutter's Avatar
Replacing ignition coils
This video makes it look really simple, is there more to it? https://www.youtube.com/watch?v=H25qLssQNxg
Also, I heard that there was an updated ignition coil from Porsche. Does anyone know where to get them? I'm replacing them in my 99 Boxster.
www.appleneworleans.com
99 Boxcutter is offline   Reply With Quote
Old 01-23-2018, 01:12 PM   #2
It really is that simple. A bit more complex if you have to replace the O rings on the tubes. You need a special tool, that you can make yourself, to pull the tubes.
1941 Dodge Luxury Liner Coupe
Old 01-23-2018, 01:15 PM   #3
That's about it , done it myself ,take your time and there should be no problem , i used BERU coil packs and they came with new bolts , good luck !
zanzibar986 is offline   Reply With Quote
Old 01-23-2018, 01:51 PM   #4
Porsche "Purist"
Paul's Avatar
Pelican has them, part number starts with 997 instead of 996.
New 997-602-104
Old:
New ones are thicker:
1987 924S. 2002 996TT. PST-2
Old 01-24-2018, 05:05 AM   #5
mikesz's Avatar
I replaced mine last year not too bad of a job. The new ones are thicker and come with longer bolts. Ironically, I was getting CEL so I started replacing the left side first. They all looked good, the ones on the right bank which were not throwing a CEL were cracked.
99 Porsche Boxster
