Old 08-08-2006, 01:10 AM   #1
fab
fab's Avatar
temperature
Everytime I start the car the temp. automatically comes on @ 72 degrees.
Is there a way NOT to have my temp. come on when i start my car?
00 Boxster Tip Blk/Blk
100% de-ambered
painted center console
painted bumperettes
autoband paint protection
wheel caps & colored crests
door sills
Valentine One
fab is offline   Reply With Quote
Old 08-08-2006, 02:01 AM   #2
Hmm this would be interesting,I would like to mine to stay off at start up as well.
Old 08-08-2006, 05:13 AM   #3
On my MY99, it seems to me that the climate control returns to the mode it was in when I last turned the car off. If I don't want the Auto mode, I manually turn off the AC by hitting the snowflake button, then tap the temperature down until it says "Lo", and set the fan manually to about 4 bars. It comes back that way on restart everytime for me.
pauldee is offline   Reply With Quote
Old 08-08-2006, 05:49 AM   #4
I would like to know if this is possible as well......It doesn't come back to the mode it was in before you shut off the car tho, I turn mine off most of the time, unless the temperatures are extreme (cold or hot)..... Always starts up automatically when I start the car...
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
Old 08-08-2006, 06:29 AM   #5
Not possible - it's the default setting. You can run the Fan speed all the way down and then hit it one more time and you'll turn the Climate Control totally OFF. Due to using one of the numeric display characters, the display will read OFf. Hope this helps...
Happy Motoring!... Jim'99
Old 08-08-2006, 06:50 AM   #6
Sorry to get your hopes up, it looks like I am alone here. I must be on drugs, or my car has been modified in some way, but I stand by my previous post - mine comes back the way I left it, after following the previously posted procedure.
Old 08-08-2006, 07:00 AM   #7
Mine always comes back the way I left it as well, maybe I am on the same drugs
Marc Gelefsky
02 996 Carrera Coupe 6 Speed Aero
86 911 Carrera Targa
http://forums.rennlist.com/rennforum...tar14266_4.gif
EX-88 951, 87 951, 86 944na, 85.5 944na 00 Audi S4..01 Boxster S .etc..etc
Marc Gelefsky is offline   Reply With Quote
Old 08-08-2006, 07:24 AM   #8
Paul, I recommend perusing your owner's manual. It may have something helpful in it for you for your boxster's model year.
I just started re-reading mine and already gleaned something new about the car that I missed the first two times.
Old 08-08-2006, 07:39 AM   #9
Randall, I totally agree on the multiple manual reads. I've read mine cover to cover several times, and it's amazing how the light bulb goes on after you've been using the car for a while. The manual is a little overwhelming on first read. However, the thread was was not started by me - "Fab" posed the question. I'm actually quite comfortable with the operation of my climate control.
Old 08-08-2006, 07:56 AM   #10
oops! Well then, Fab, read your manual!
Old 08-08-2006, 08:18 AM   #11
1JB
Mine works exactly as Pauldee said. If I have the auto climate set to say 71 then turn it off by toggling down until it reads off and then hit auto it comes back on at 71. I know for a while it kept coming back on at 72 but now it comes back on to my setting. I'm going to have to check the procedure to be certain this is how I do it.
2006 Boxster S
Midnight Blue/Metropol Blue Top
Bi Xenons
Auto Climate
Bose with Windstop
CD Changer
Heated Seats
Clear Sidemarkers
Midnight Blue Side Vents
1JB is offline   Reply With Quote
Old 08-08-2006, 11:18 AM   #12
Ronzi's Avatar
After some testing on my own car (a '99), if you want the whole system to be off at startup, you have to run the temp control all the way down, one punch past 65 to Lo, then run the blower speed down to OFf. Turn off the engine and restart and it will start up with the temp on Lo and the fan OFf. At least mine does.
The minute you increase the fan speed or temp settings, (or set to AUTO) it will bollix up the works and it will not return to Lo/OFf unless you reset it that way before engine shutoff.
I agree with several others, the default operation seems to be to bring up the (hv)AC system at whatever the settings were when the engine was shut off.
If the engine was shut off with the AC in AUTO mode, it will come up in AUTO and self adjust the temp and blower settings to reach the preset temp.
Ronzi is offline   Reply With Quote
Old 08-08-2006, 03:30 PM   #13
fab
fab's Avatar
Randall....Randall.. Randall....having a bad day. I just asked a general question.
100% de-ambered
painted bumperettes
door sills
Valentine One
Old 08-08-2006, 03:37 PM   #14
slogans7's Avatar
Same here. I mean, I also must be on drugs. But my temp starts where I left it. Guess we're the lucky ones.
2002 Triple-Black Boxster S
slogans7 is offline   Reply With Quote
Old 08-08-2006, 07:47 PM   #15
These are great drugs!
Marc Gelefsky
Old 08-09-2006, 07:02 AM   #16
Fab, I didn't mean to come off sounding that way... forgive me.
... I took my own advice, by the way. Just skimmed mine this morning again and discovered that the button for the rear window defroster (hardtop option) also defrosts the side mirrors. I never knew I had heated side mirrors before this morning. I don't have to pay anyone for this newfound feature, do I?
Old 08-09-2006, 10:54 AM   #17
fab
fab's Avatar
Randall- Your forgiven.
See you learned something new.
100% de-ambered
painted bumperettes
door sills
Valentine One
Old 08-09-2006, 11:24 AM   #18
Porscheectomy
I believe that if you turn the climate control off, then turn the car off, it will come up at 72 degrees and the fan blowing fairly hard. If the climate control is on when the car is off, the climate control setting is saved when you turn the car on again.
Old 08-09-2006, 11:26 AM   #19
If I turn my Climate Control off it will stay off when I restart the car.
Marc Gelefsky
Old 08-09-2006, 01:45 PM   #20
Say i turn my car off with the climate control set to off, Once i turn my car back on, the climate control goes back on to the last automatic temp i had it on last.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
