Boxster General Discussions
Wheel Bolt Size When Moving to 18"
11-04-2017, 08:18 PM
Ciao
Ciao's Garage
Joy Ride
Work Horse
When installing a 18" wheel from a 17" wheel do you need to get longer wheel Bolts?
Front; Offset: 50mm
Rear: Offset: 47mm for 10J 52 mm for 9J
5280 Cruising @High Altitude
Seal Gray & K&N Filter
11-05-2017, 05:12 AM
2
deathsled986
No. You only need longer bolts if you use spacers to space the wheels out further than their normal offset.
11-05-2017, 12:27 PM
3
PaulE
Assuming they are all OEM wheels too. Not sure if any aftermarket wheels require different length lug bolts.
Linear Mode
Switch to Threaded Mode
07:38 AM
