Old 10-03-2017, 07:40 AM   #1
DrCactus's Avatar
Lightbulb Locked Car - 1 HONK ??
Hey folks, I got to work today and locked my car via remote and my car HONKED once... I checked to make sure the hood and the trunk both were closed and tried to lock the car again and STILL get 1 HONK.
Any ideas what else could be causing this HONK ?
DR.
DrCactus
Old 10-03-2017, 07:49 AM   #2
98 Arctic silver 986
tommy583's Avatar
Center console not latched will also cause this.
Old 10-03-2017, 08:21 AM   #3
DrCactus's Avatar
Do you mean the little glove box compartment between the seats? I will take a look as I did have it open this morning... thanks.
DrCactus
Old 10-03-2017, 08:28 AM   #4
2003 S, Arctic Silver, M6
paulofto's Avatar
I get the 'one honk/one light flash' issue sometimes as well. I'm not sure what the issue is but sometimes just opening the drivers door fixes the problem, sometimes opening and closing the console or glove compartment does it. I'm guessing I'll have to try and get at all the contacts for the microswitches and try and clean and/or replace them.
Old 10-03-2017, 09:04 AM   #5
Porsche9's Avatar
Likely a faulty micro switch somewhere. On my Carrera it was the glove box.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 10-03-2017, 09:10 AM   #6
Any way to determine exactly which sensor is the problem? Is there something in my Durametric?
Old 10-03-2017, 06:03 PM   #7
tommy583's Avatar
Yes that is what i was talking about.
Old 10-04-2017, 04:41 AM   #8
DrCactus's Avatar
You nailed it... thanks Tommy.
DrCactus
Old 10-04-2017, 05:16 AM   #9
tommy583's Avatar
Your welcome, glad I was able to help.
Old 10-04-2017, 08:40 AM   #10
BruceH's Avatar
My center console does it every so often, in fact it did yesterday! Closed it firmly, no more honk
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 10-04-2017, 12:00 PM   #11
GTA_G20's Avatar
You guys are lucky i get the double honk
GTA_G20 is offline   Reply With Quote
Old 10-04-2017, 12:31 PM   #12
It's not supposed to honk when I lock it? ��
deathsled986 is offline   Reply With Quote
Old 10-04-2017, 01:00 PM   #13
Porsche9's Avatar
Nope. When it honks it the car telling you something isn't right. Usually something is left open or a micro switch has failed.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 10-06-2017, 01:25 PM   #14
CoBeerToad's Avatar
I get it every now and then, but my top is manual, so I know it's the microswitch under the... deck thingy, I guess it's called. Sometime the top is not sitting down all the way or it's still stiff from being up all winter. I leave the top down all summer so by June, it usually isn't a problem anymore.
CoBeerToad is offline   Reply With Quote
Old 10-11-2017, 05:10 PM   #15
98Sixer's Avatar
Just replaced the stock CDR 220 Becker with a Pioneer Blue Tooth Set-up. Since I picked up the car, I now have the dreaded 1 Honk every time the car is locked or unlocked.
Can this somehow be related or does the timing of all this just make it seem that way?
1973 914 2.0-Marathon Blue Metallic (Funday Driver)
1972 VW Beetle Convertible-Saturn Yellow (Sunday Driver)
2013 Panamera S Platinum Silver Metallic (Daily Driver)
2002 Boxster 2.7-Lapis Blue Metallic (Don't Even Ask!)
98Sixer is offline   Reply With Quote
Old 10-11-2017, 07:24 PM   #16
KevinH1990's Avatar
It is most likely related. If you look at the CDR 220 you removed, there is a sticker on one side of the radio. (I think it is on the left side.) This matches up with an electrical connection. If the sticker isn't present, it will cause the anti-theft system to think the radio has been moved. Put a piece of electrical tape on your new radio in the same location as the sticker on the Becker unit. That should fix the problem.
See this thread for a more detailed explanation: http://986forum.com/forums/boxster-general-discussions/12517-aftermarket-cd-immobiliser.html
Old 10-11-2017, 07:53 PM   #17
98Sixer's Avatar
Makes sense and thanks for making me aware of a 10 year old solution to my new problem!
